159 su Auto Motor und Sport
walhalla
Stefano hai bevuto stamattina? Il master test lo leggi solo quando ti interessa? E non solo il master test ma anche moltissime altre prove su strada, tutte concordi sul fatto che la Honda Accord non ha assolutamente un bel comportamento dinamico. Altro che sospensioni a livello della 159 e telaio solo leggermente inferiore.
Non sono stefano73 :D
Per me quel master test ha veridicità nulla. Non lo leggo, ne' dove mi interessa ne' dove non mi interessa.
Le prove... lasciale stare le prove. Facciamo che tu la provi, e come si deve, dopodichè ne riparliamo ok? ;)
  • Risposte 333
2)Honda is better in handling than Subaru-Mitshu??
As a sheer handling, yes it is. I mean a sporty Honda, such as NSX, for it is obvious that an Accord can be as handly as an Impreza.
Otherwise, as overall road yield and effectiveness, Lancer and Impreza are better due to their 4wheel drive, their differential and their harder setups.
You are totally wrong....
I never said that alfa was the only house to use it in the d segment even if currently is the only one in pair with lexus is to have front double wishbone in the d premium segment.
Mcpherson is worst than double wishbone and has far more limits in it's set up and drivetrain precision that can't be adjusted even by an excellent set up ...and is a hideous system for proper modern sportcars...no serious modern sportcar should use a scheme like that cause lacks precision....
Naturally even a double wishbone with an odd set up wouldn't work good, but has much upper limits than the mcpherson scheme.....
p.s.Honda is probably the best handling japanese company but in general japanese's are not the best in set up and suspension geometry...
1)What do you mean drivetrain precision & upper limit?
3)Panda's 4wd is also from magna steyr....same provider with Porsche?
ps-sorry for the repost...
Su strada aperta, e guidando normalmente, qualunque vettura è sicura ed ha un comportamento accettabile. Se mi date una Honda Accord da testare al limite in pista è un'altro paio di maniche. Ma il classico giretto dal conce non mi servirebbe a nulla. Per cui mi tengo come prove i video di Vox e i pareri di tutte le riviste europee e non.
Per quanto riguarda Stefano...non so perchè ma ho sbagliato...scusami :)
P.S. Tu la 159 però l'hai provata?
Luca, mi tocca di dar ragione al caro JTD su accord.
E ricordati che quello a cui ti riferisci, e lo so benissimo, nel 92/93 portava a costi impensabili allora e poco sostemibili oggi su seg.C.
Rimane il fatto che honda sono le Jap migliori tecnicamente, honda è una piccola bmw, non ha ne avrà mai (xkè non possono ne soprattutto vogliono) le dimensioni di toyota. Sarebbe un esempio da seguire x Alfa, a livello di impostazione strategica.
(John Fitzgerald Kennedy)
1)i mean that a drivetrain with double wishbones compared to one with mcpherson gives you more drivetrain suspension and upper limits...that's the reason you wouldn't find any proper sportcar with mcpherson even porsche in it's high end carrera GT supercar use double wishbone.
2)Depends on model and version, but generally i would say yes.
3)yes.
Hai visto il video sul cambio di corsia?
L'Accord scoda vistosamente e si corica, la 159 è fulminea e stabile, solo un filo di sottosterzo iniziale.
l'accord e' stata mediocre a livello di sicurezza attiva e handling in tutti i test letti in europa...quello che compromette lo schema di sospensioni ottimo sono 4 cose la rigidita' torsionale della scocca solamente discreta per una vettura moderna...poco piu' della meta' di quella di 159...la geometria sbagliata specialmente della sospensione posteriore...il set up non ottimizzato...ed infine il rapporto passo carreggiate...
