fire vs TU
Net Flier
ed eccoci qui, in attesa del grande dio unico conoscitore di tutti gli alesaggixcorsa dei fire, il mitico stev66 che ha fatto finta di non capire nel topic della biemme.. :mrgreen:
TU
TU9 /K 70.0 x 62.0 mm 954 cm3 45 ch Carbu simple corps
TU9 M/Z 70.0 x 62.0 mm 954 cm3 50 ch Injection, catalyseur
TU1 /K 72.0 x 69.0 mm 1124 cm3 55 ch Carbu simple corps
TU1 F2/K 72.0 x 69.0 mm 1124 cm3 60 ch Carbu simple corps
TU1 M/Z 72.0 x 69.0 mm 1124 cm3 60 ch Injection, catalyseur
TU1 JP 72.0 x 69.0 mm 1124 cm3 60 ch Injection, catalyseur
TU2 4A 75.0 x 73.2 mm 1294 cm3 95 ch 2 carbus double corps
TU2 4A/K 75.0 x 73.2 mm 1294 cm3 103 ch 2 carbus double corps
TU2 J2/Z 75.0 x 73.2 mm 1294 cm3 100 ch Injection, catalyseur
TU3 A 75.0 x 77.0 mm 1360 cm3 65 ch Carbu simple corps
TU3 A/K 75.0 x 77.0 mm 1360 cm3 70 ch Carbu simple corps
TU3 F2/K 75.0 x 77.0 mm 1360 cm3 75 ch Carbu double corps
TU3 M/Z 75.0 x 77.0 mm 1360 cm3 75 ch Injection, catalyseur
TU3 JP 75.0 x 77.0 mm 1360 cm3 75 ch Injection, catalyseur
TU3 S 75.0 x 77.0 mm 1360 cm3 85 ch Carbu double corps
ET3 J4 75.0 x 77.0 mm 1360 cm3 90 ch Injection, catalyseur
TU3 FJ2/Z 75.0 x 77.0 mm 1360 cm3 95 ch Injection, catalyseur
TU3 FJ2/K 75.0 x 77.0 mm 1360 cm3 100 ch Injection
TU5 JP 78.5 x 82.0 mm 1587 cm3 90 ch Injection, catalyseur
TU5 J2/L3 78.5 x 82.0 mm 1587 cm3 105 ch Injection, catalyseur
TU5 JP4 78.5 x 82.0 mm 1587 cm3 110 ch 16 soupapes, catalyseur
TU5 J4 78.5 x 82.0 mm 1587 cm3 120 ch 16 soupapes, catalyseur
TUD3 75.0 x 77.0 mm 1360 cm3 53 ch Diesel
TUD5 77.0 x 82.0 mm 1527 cm3 58 ch Diesel, catalyseur
e sbrigati che non hai tempo per lavorare, devi fare la tabellina :lol:
  • Risposte 33
Top Posters For This Question
Giorni di maggior attività
fire
769cc 8v
999cc 8v
999cc 16v SMPI (solo in Brasile)
1108cc 8v SPI
1108cc 8v MPI
1242cc 8v SPI
1242cc 8v MPI
1242cc 16v SMPI
1368cc 8v SMPI
1368cc 16v SMPI
a cui vanno aggiunti i recenti tjet ed il 1.3 a nafta..chiaramente mancano alesaggi e corsa, perché non li so e non li ho trovati..
interessante, si potrebbe aggiungere pure il peso delle varie versioni e cilindrate che negli anni è mutato. Per i FIRE si trovano facilmente , i pesi, il problema sono i Peugeot
beh dai simo..figa tu trovi..intanto metti quello che trovi..qui manca tutto, non trovo tutti gli alesaggi e, sinceramente, non so nemmeno dove andarli a recuperare uno per uno..
per gli ultimi FIRE con i pesi ci penso io, subito.Senza i turbo ,che però vedrai che le loro misure interne coincideranno con alcuni di questi . Ti lascio però l'onere di organizzare il tutto in ordine cronologico.
FIRE 1108 MPI E4
Cilindrata x Alesaggio: 70x72 mm
Potenza: 54 CV @ 5000 giri/min
Coppia: 90 Nm @ 3000 giri/min
Dimensioni (LxLxH): 475x442x576 mm
Massa: 90 Kg
FIRE 1242 MPI E4
Cilindrata x Alesaggio: 70,8x78,9 mm
Potenza: 60 CV @ 5000 giri/min
Coppia: 102 Nm @ 3000 giri/min
Dimensioni (LxLxH): 475x442x595 mm
Massa: 92 Kg
Bi-Fuel (Benzina+CNG)
FIRE 1242 MPI E4
Potenza: 65 CV @ 5500 giri/min
Coppia: 104 Nm @ 3000 giri/min
Massa: 84 Kg
Exhaust port-driven swirl
FIRE 1242 MPI 4V E4
Potenza: 80 CV @ 5250 giri/min
Coppia: 113 Nm @ 4000 giri/min
Dimensioni (LxLxH): 475x442x689 mm
Massa: 103 Kg
FIRE 1370 MPI E4
Cilindrata x Alesaggio: 72x84 mm
Potenza: 77 CV @ 5750 giri/min
Coppia: 114 Nm @ 3000 giri/min
Massa: 85,5 Kg
Exhaust port-driven swirl + CVCP
FIRE 1370 MPI 4V E4
Potenza: 90 CV @ 6000 giri/min
Coppia: 125 Nm @ 4500 giri/min
Massa: 103 Kg
FIRE 1370 PDA 4V E4
Potenza: 95 CV @ 6000 giri/min
Coppia: 125 Nm @ 4750 giri/min
Massa: 102,6 Kg
Port deactivation + CVCP
manca il 100cv e i vecchi a carburatori e i primi a iniezione che guarderò di trovare nei prossimi giorni.
minghia!
mo' so' cazzi miei! :lol:
famme vede di sistemà sto casino
Su carsfromitaly ci sono tutti gli alesaggi.
768 (65x58)mm 34hp@5250rpm
999 (70x64.9)mm 45hp@5000rpm
1108 (70x72)mm 50hp/54hp@5250rpm
1242 (70.8x78.86)mm 60hp/65hp/69hp@5000/5500rpm
1242 16v (70.8x78.86)mm 80hp@5500rpm
1368 (72x84)mm 77hp@6000rpm
1368 16v (72x84) 90hp/95hp@5500/5800rpm
1368 T-Jet (72x84) 120hp/150hp@5000rpm
Il Mj non è un fire..... ha girato all'inizio col basamento fire rinforzato, ma la versioen definitiva non deriva dal fire.
Mi so perso qualcosa....... ma ci stavo perdendo uan vita :D
768 8v (65x58 )mm 34hp@5250rpm
999 8v (70x64.9)mm 45hp@5000rpm
1108 8v (70x72)mm 50hp/54hp@5250rpm spi/mpi
FIRE 1108 MPI E4
Massa: 90 Kg
1242 8v (70.8x78.86)mm 60hp/65hp/69hp@5000/5500rpm spi/mpi
FIRE 1242 MPI E4
Massa: 92 Kg
FIRE 1242 MPI E4
Massa: 84 Kg
1242 16v (70.8x78.86)mm 80hp@5500rpm mpi
FIRE 1242 MPI 4V E4
Massa: 103 Kg
FIRE 1368 MPI E4
Massa: 85,5 Kg
FIRE 1368 MPI 4V E4
Massa: 103 Kg
FIRE 1368 PDA 4V E4
Massa: 102,6 Kg
1368 T-Jet 16v (72x84) 120hp/150hp@5000rpm
così ha un pochino più di senso..cmq, una cosa..ma cos'è sto 1368 che ho segnato io, in luogo del tuo 1370?
ps
ho riorganizzato tutto dopo il post di beta..
uhm..avevo letto da qualche parte che lo davano come fire però..solo che non riesco più a trovare dove..
Il Fire 1.4 è 1368, ma molti datasheet riportano 1370 per "fare cifra tonda" :D.
IL MJ non è un Fire...... e te lo posso assicurare perchè ho un amico abbastanza invischiato con lo sviluppo di sto motore (e mi fa sempre due palle cosi tessendone le lodi! :D ) .
I primi muli per testare non so cosa li hanno fatit partendo dai basamenti del fire...... ma il nuovo basamento è totalmente diverso.
si, la storia dei muli la conosco anche io, tant'è che pure su quattrorisate apparve sta cosa..;)
