Non più in vendita; per il Nuovo Modello cliccate sul seguente link
freccina19rossaiy0.gifhttp://www.autopareri.com/forum/suzuki/61472-suzuki-swift-facelift-topic-ufficiale.html
4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg
2011-Suzuki-Swift-28.jpg 2011-Suzuki-Swift-27.jpg 2011-Suzuki-Swift-26.jpg 2011-Suzuki-Swift-25.jpg 2011-Suzuki-Swift-24.jpg 2011-Suzuki-Swift-23.jpg 2011-Suzuki-Swift-22.jpg 2011-Suzuki-Swift-21.jpg 2011-Suzuki-Swift-20.jpg 2011-Suzuki-Swift-19.jpg 2011-Suzuki-Swift-18.jpg 2011-Suzuki-Swift-17.jpg 2011-Suzuki-Swift-16.jpg 2011-Suzuki-Swift-15.jpg 2011-Suzuki-Swift-14.jpg 2011-Suzuki-Swift-13.jpg 2011-Suzuki-Swift-12.jpg 2011-Suzuki-Swift-7.jpg 2011-Suzuki-Swift-6.jpg 2011-Suzuki-Swift-5.jpg 2011-Suzuki-Swift-4.jpg 2011-Suzuki-Swift-3.jpg 2011-Suzuki-Swift-2.jpg 2011-Suzuki-Swift-1.jpg
4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg6.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg4.jpg
carscoop e km77
Press Release :
Suzuki is pleased to announce the first images and preliminary information of the new, third generation Swift which goes on sale in the UK in the Autumn.Suzuki held the world premiere line off ceremony today for mass production of the new car at its Magyar Suzuki Corporation production facility at Esztergom, in Hungary.
The all-new Swift is positioned as Suzuki’s latest world strategic model and makes strong developments in styling, impact safety, driving performance, handling, improved fuel consumption and significantly lower emissionsicon1.png.
Extensive use of higher strength steel makes the new bodyshell lighter and stiffer than before as well as offering refinement in underbody design. This latest body design has also helped improve impact safety for pedestrians as well as occupants.
Increased track and larger diameter wheels with lower profile tyres allow for even better handling than the already highly acclaimed outgoing Swift that first went on sale in 2005.
The interior design now has a more dynamic feel, featuring black as its keynote colour with accents of silver throughout the car.
New Swift has grown slightly in length (+90mm) with a 50mm increase in wheelbase; full dimensions are as follows:
[TABLE=width: 100%]
[TR]
[TD=width: 30%][/TD]
[TD=width: 47%]New Swift[/TD]
[TD=width: 23%]Previous Swift[/TD]
[/TR]
[TR]
[TD=width: 30%]Length[/TD]
[TD=width: 47%]3,850mm[/TD]
[TD=width: 23%]3,760mm[/TD]
[/TR]
[TR]
[TD=width: 30%]Width[/TD]
[TD=width: 47%]1,695mm[/TD]
[TD=width: 23%]1,690mm[/TD]
[/TR]
[TR]
[TD=width: 30%]Height[/TD]
[TD=width: 47%]1,510mm[/TD]
[TD=width: 23%]1,500mm[/TD]
[/TR]
[TR]
[TD=width: 30%]Wheelbase[/TD]
[TD=width: 47%]2,430mm[/TD]
[TD=width: 23%]2,380mm[/TD]
[/TR]
[TR]
[TD=width: 30%]Front Track[/TD]
[TD=width: 47%]1,480mm (16-inch wheels)[/TD]
[TD=width: 23%]1,470mm[/TD]
[/TR]
[TR]
[TD=width: 30%]Rear Track[/TD]
[TD=width: 47%]1,485mm (16 inch wheels)[/TD]
[TD=width: 23%]1,480mm[/TD]
[/TR]
[/TABLE]
For the powertrain; a new 1.2-litre petrol engine incorporating Dual VVT (Variable intake and exhaust valve timing) is utilised which produces 94PS at 6,000rpm, slightly more than the outgoing 1.3-litre unit. Torque is also improved to 118Nm at 4,800rpm.
Fuelicon1.png consumption on the combined cycle is now 56.5mpg for the manual transmission model, an improvement of 7.8mpg over the previous 1.3-litre unit.
Emissions are much lower as well; the new 1.2-litre engine with manual transmission produces just 116g/km on the combined cycle; representing a 24g/km or 17 per cent improvement over the 1.3. An optional automatic transmission will be available for the petrol engine from launch.
A 1.3-litre diesel engine will also become available and planned for UK introduction in early 2011; this engine emits 109g/km (down from 119g/km) and has an impressive combined fuel consumption of 67.3mpg, an improvement on an already highly credible 62.8mpg from the outgoing Swift DDiS. This Euro 5 engine has more precise engine management than before with reduced levels of mechanical friction for smoother running and flexibility.
A further selection of images will be available later this month and details on full UK specification and pricing will be announced later in the summer.
Suzuki
Modificato da Touareg 2.5
  • Risposte 99
  • Visite 65.3k
Beh, cambia pochissimo ma cambia bene..
Sì trovo abbia un design semplice e simpatico... l'opposto di quello sovraccarico stile DS3.
Personalmente tra i due estremi preferisco questo.
Then go racin' in the street
Cambia poco, aspetto altre foto per giudicare meglio e soprattutto in altri colori perchè in rosso non rende molto (anche perchè sebrano quasi fotoshops sulla base della Swift attuale :D).
Prima cosa che si nota però è che hanno ingrandito molto i fari.
Notare che si vedono già le influenze Volkswagen, in queste foto monta l'antenna corta e flessibile che c'è su Polo :mrgreen:.
Comunque la Swift mi è sempre piaciuta ed anche questa fa sperare bene una cosa su cui spero abbiano lavorato sia l'aumento della qualità degli interni.
P.S.
Sono io che ci vedo male oppure monta ancora le spazzole tergicristalli con "telaio"?
Modificato da MotorPassion
i fari ,così come il frontale,non mi piace molto.....
di profilo invece è sempre molto carina......speriamo migliori molto dentro...
