MotorPassion
CTG_FL_iVe_BS_Street_007-edited-1440x891
The ŠKODA CITIGOe iV Is Here. What’s Hidden inside?
ŠKODA has unveiled its first electric production car, the CITIGOe iV, at the IIHF Ice-Hockey World Championship. Let’s take a closer look at the technology offered by the new model.
What sort of engine does the car have?
It is a three-phase permanent neodymium magnet synchronous electric motor. A synchronous motor is more efficient than an induction motor, but also more costly to purchase.
How powerful and fuel efficient is it?
The electric motor delivers 60 kW, which is 5 kW more than the most powerful internal combustion engine. One of the biggest advantages is the electric motor’s torque of 210 Nm, available from zero rpm. This makes for a better driving experience and enhanced vehicle dynamics compared to a 95 Nm internal combustion engine. Efficiency depends on the user’s driving style and on ambient conditions, but realistically we are looking at between 12 and 15 kWh per 100 km.
Is the motor different in size and weight from an internal combustion engine?
Compared to the 1.0 MPI engine fitted in conventional CITIGOs, the CITIGOe iV’s electric motor is more compact and more or less the same weight.
The electric motor is smaller and easier to install than an ICE. As far as weight is concerned, the electric motor itself weighs 54.1 kg, which is a tad more than the internal combustion engine’s 50.5 kg. However, to make a proper powertrain comparison we should also factor in the gearbox. This results in a 70.4 kg electric motor and 80.2 kg ICE, mainly because the electric motor transmission has a single gear, making it much simpler and lighter.
What is the battery capacity, where is the battery located and how heavy is it?
The Li-ion battery capacity is 36.8 kWh, allowing the customer to travel up to 265 km on a single charge. The battery weighs 248 kg. It is located under the floor of the car and also occupies the space under the rear seats.
How long does it take to charge a battery?
The fastest option is to charge from a DC rapid charging point, which can charge a flat battery to 80% total capacity in about an hour. Using a home-charging wallbox, it should take 4:08 hours to reach the same capacity, or just under 5 hours 30 minutes to fully recharge the battery.
Has electric drive necessitated any changes to the car’s design?
The drive unit has been designed to allow for installation in the place primarily intended for the internal combustion engine. The high-voltage battery, taking up the space previously occupied by the now redundant fuel tank, the place left behind by the exhaust pipe in the tunnel console and the under-seat space, has also had to be adapted.
Is there any difference in the transmission from the driver’s point of view?
It is a single-speed reducer that, as far as the customer is concerned, behaves like an automatic transmission. It is absolutely smooth, without any torque drop at all.
Do the dashboard indicators differ in any way? Any extras, anything missing?
In addition to the standard indicators, the instrument panel includes a battery indicator and information on the range remaining. The dominant indicator is the pointer display for driving mode, which indicates the relative power of the drive or the relative level of brake energy regeneration for the high-voltage battery.
Modificato da MotorPassion
  • Grazie! 2
Come le altre del trio, Citigo sconta alcune poracciate (vedi vetri a compasso) che me la farebbero scartare al volo. Per il resto direi senza infamia e senza lode, una citycar elettrica il cui successo immagino dipenderà dal prezzo del leasing per le flotte, non so quanti privati potranno spendere certe cifre per una segmento A.
C'è solo una cosa che mi stupisce: ha il Lane Assist. Sbaglio o è una novità per il trio di citycar VAG?
  • Pandino ha messo in primo piano/indicizzato questa Discussione
1 ora fa, Tommy99 scrive:
Non vedo quale possa essere il suo scopo sul mercato
Auto urbana a zero emissioni, come: Zoe, prossima Smart, Honda-e, ecc... Oltre che al marketing ed abbassare il livello emissioni medie della gamma del marchio (problema che però non riguarda Skoda)
  • Mi Piace 1
Da quello he si intravede, sono stati adottati gli interni presenti su UP restyling come anche le frecce sugli specchietti.
2 ore fa, Tommy99 scrive:
Car sharing.
6 ore fa, KimKardashian scrive:
Ci hanno messo 3 anni per rimarchiare la e-UP? ?
La Citigo ha una autonomia maggiore. ☺️
Poi per ora in Italia la e-UP! non viene più commercializzata.
Parlavano di prezzo <20k€.
Se confermato sarebbe interessante come auto puramente cittadina, visto che l'autonomia non è affatto male.
