Hyundai - CVVD Continuously Variable Valve Duration
Ragazzi ho trovato questo articolo su quattroruote.
https://www.quattroruote.it/news/tecnologia/2019/07/03/hyundai_motore_cvvd_smartstream_g1_6_t_gdi.html
A quanto pare in Hyundai hanno sviluppato un sistema che rende svincolate le fasi di apertura e chiusura delle valvole.
Potreste aiutarmi a comprendere meglio la tecnologia?
Grazie mille!:)
☏ POCOPHONE F1 ☏
A voi!
Non ho tempo, ma l'ho trovato ben spiegato su GreenCarCongress.
Hyundai Motor Group has developed the first Continuously Variable Valve Duration (CVVD) technology to feature in future Hyundai and Kia vehicles. The innovation was revealed at Hyundai Motorstudio Goyang on Wednesday alongside the Smartstream G1.6 T-GDi—the first engine to feature the technology.
CVVD optimizes both engine performance and fuel efficiency while reducing emissions. The valve control technology regulates the duration of valve opening and closing according to driving conditions, achieving a 4% boost in performance and a 5% improvement in fuel efficiency. The technology cuts emissions by 12%.
Press Photo_1_Edit
Internal combustion engine’s performance and efficiency are currently governed by variable valve control technology that adjusts the timing of valve opening and closing and depth of the valve’s opening, with engine power produced through the fuel intake-compression-expansion-exhaustion cycle.
Typical variable valve control technologies manage the timing of the valve’s opening and closing (as in Continuously Variable Valve Timing - CVVT) or control the volume of air admitted by adjusting the depth of the opening (Continuously Variable Valve Lift - CVVL).
Previous variable valve control technologies could not regulate valve duration, as the valve’s closing timing was subordinate to opening timing and could not respond to diverse driving situations. CVVD takes the technology in a new direction by adjusting how long a valve is open.
When the vehicle is maintaining a constant speed and requires low engine output, CVVD opens the intake valve from the middle to end of the compression stroke. This helps to improve fuel efficiency by reducing the resistance caused by compression.
On the other hand, when engine output is high, such as when the car is driving at a high speed, the intake valve is closed at the beginning of the compression stroke to maximize the amount of air used for the explosion, enhancing torque to improve acceleration.
542054
Smartstream G1.6 T-GDi engine. Unveiled alongside the new CVVD technology was the new Smartstream G1.6 T-GDi Engine, a four-cylinder gasoline turbo unit with 180 horsepower and 27.0 kgm (265 N·m) of torque. The new powertrain is the first to utilize the Group’s new CVVD technology and also features Low-Pressure Exhaust Gas Recirculation (LP EGR) to further optimize fuel efficiency.
The exhaust gas recirculation system returns some of the gas burnt by the engine to the combustion chamber, producing a cooling effect and reducing the emission of nitrogen oxides. The G1.6 T-GDi also features a low-pressure system that redirects the burnt emission gas to the front of the turbocharger compressor, rather than the intake system, to increase efficiency under the high load condition.
Additionally, the new unit has an Integrated Thermal Management System that quickly heats or cools the engine to an optimal temperature, and a strong direct spray system that achieves 350 bar, surpassing the 250 bar of the previous T-GDi engine. In addition, engine friction is reduced by 34% with the application of low friction moving parts.
The new Smartstream G1.6 T-GDi engine will be applied in the Hyundai Sonata Turbo, which is set for introduction in the second-half of this year. This premiere will mark the first in a series of new Hyundai and Kia vehicles featuring the engine.
https://www.greencarcongress.com/2019/07/201090703-cvvd.html
Praticamente è un'evoluzione meccanica del Bi-VANOS di BMW.
Però Quattroruote sbaglia quando dice che è il primo sistema al mondo a gestire la durata di apertura della valvola, Multiair lo può fare.  BMW credo di no, cambia alzata , anticipo e ritardo, ma la durata la decide la camma
2 minuti fa, mydog scrive:
Esattamente. Gli unici che già fanno questo "gioco" al completo sono il Multiair e questo, BMW è ancora vincolata meccanicamente al sistema.
Il punto è che se entra in produzione il Camless realizzato da Koenigsegg, questi sistemi saranno belli che superati.
1 ora fa, Beckervdo scrive:
I multiair di JLR possono farlo, i "nostri" non possono variare fase ed eventualmente incrocio valvole senza sacrificare l'alzata (che ha un profilo fail-safe)
mi spettavo che si sarebbe diffusa una tecnologia specifica come è avvenuto nel diesel con il common rail  invece ognuno si è inventato la propria.  Sul Multiair secondo me non ci stanno investendo abbastanza,  probabilmente potrebbe funzionare anche senza albero a camme .  Forse ha bisogno di un circuito specifico di olio, rispetto ad ora che usa l'olio motore
