Human Horizons
4200blu
Il secondo modello di HiPhi, ramo automotive dell aHuman Horizons, la "Z" parte fra poco sul mercato.
Overall, the design is brilliant: wide wheel arches, a spoiler that floats above the boot lid, a full-width LED light unit, and a strangely simple black bumper. The HiPhi Z gets rear wheels that can steer or counter-steer up to 13.2 degrees. Additionally, the sedan is equipped with a (semi-)autonomous driving system that consists of smart software, 34 sensors, and the necessary radar systems.
The interior doesn’t disappoint, either. There is no instrument panel, but it has a HUD. However, what catches the eye is the screen. Instead of boring icons positioned along horizontal and vertical axes, the Z uses a 3D cube that holds all the apps. The driver can rotate the cube with his fingers to get to the needed app. At the top are the main indicators like speed, navigation, and range. At the bottom, you’ll find a few fixed buttons for the air conditioning system.
The screen is bolted on a robotic arm, able to swirl and turn around in all directions. The system is called the HiPhi Bot and turns itself to the person who speaks. So if the driver gives a command, the screen turns towards them, and the same happens when the passenger gives a command. To top it off, the screen can also move to the music rhythm played on the car’s 23-speaker Meridan audio system.
While the HiPhi Z has the same powertrain as the X, it gets a larger battery: a 120 kWh unit good for a range of 705 kilometers NEDC. There are two powertrain options. The first is a single motor, rear-wheel drive capable of producing 300 hp and 410 Nm. Alternatively, users can go for the dual motor, four-wheel drive. with 600 hp and 820 Nm. With the dual-motor setup, the Z goes from 0-100 in just 3.8 seconds.
(CNC)
