Weixin-Image_20250103113113-1-1068x729.jpg.faf7cc6534f3d547c72651a06b15b57b.jpgWeixin-Image_20250103113035-1.thumb.jpg.b271c9405b1c21dc6794df66381a6c62.jpgautohomecar__ChxoHmd2XHOAZRGlAADSoYKylTI231.jpg.806a5949f6e5bfb1a6fbd55c6284f877.jpg9f291ab9ly1hx7ho6vli9j20wr0mewhh.jpg.d57da1b46f15793e4a5c432f477a5ddd.jpgIMG_20250103_201620_783.jpg.68afc7029ea0ea8cc84d858281aac9d1.jpgIMG_20250103_201620_679.jpg.2bbb3a7d43819b3647bef71f64c282b3.jpgIMG_20250103_201620_591.jpg.108b5bc397ac49f22ad4ab549f7090e3.jpgautohomecar__ChxoHmd2XHWATKEMAANXjoHMcPY731.thumb.jpg.9c0d050960ac5d7b5066861f5a998cf3.jpgIMG_20250103_201620_653.jpg.af323cc20007871f0c7a76c98453af09.jpgautohomecar__ChtlyGd2XHWAV92ZAARqyC6sRIw160.thumb.jpg.2840260b4ba7ecac5cdaa7ea64e5cabc.jpgautohomecar__ChxoHWd2XHSAPCSHAAQq4TtXTZI432.thumb.jpg.bc5bf28a25342263089c05ff9fa4222a.jpgWeixin-Image_20250103113128-1.thumb.jpg.ad62f5a6d9b0c2f23104f8a50bc388e1.jpgautohomecar__ChxoHWd2XHWAOPmIAATR9iff7v0985.thumb.jpg.a0163c6d822f102f5a5cdf96b656df2a.jpgautohomecar__ChtlyGd2XHWADHZwAAUn8gUZMaE285.thumb.jpg.5df178d7781477a95bdd504647de63ba.jpgIMG_20250103_201621_121.jpg.5e6fd7d5a3c9836bc5189ba217c8c828.jpgautohomecar__ChxoHWd2XHWAJVZpAARcJYz7ays722.thumb.jpg.b21b04e7e3f2f266d59692fb9cfc1605.jpgIMG_20250103_201621_266.jpg.98365a21c5087d26c50dd76f2d764748.jpgautohomecar__ChtlyGd2XHWAFnnxAAQImQq1ebs347.thumb.jpg.e4b916ef454eed591ccfdaec342bb406.jpgautohomecar__ChxoHmd2XHSACNPUAAMQHNd-V6g225.thumb.jpg.160e3b3e367d747ae6e7ab7d2f6635b0.jpgautohomecar__ChxoHWd2XHWADVfLAAQhDyQSwqg690.thumb.jpg.b688d11b97fd50c61888e6fb7e7db9c1.jpg
autohomecar__ChxoHmd2vCaAMiw6ADRB3fpz9HE144.thumb.jpg.483149486d875b712a4bc2a5737735ba.jpg97eb2e5307374eb4acb041a2cbf68683.png.c62229a8c3a76be5db69410c1ebe737a.png68de6794122e4434ae7050ff2c57ce67.png.bb089bdfff6e2c1113f53e410aebf08c.pngautohomecar__ChxoHmd2XHWAXvi6AAdbL8MqQFg204.thumb.jpg.87fdcd6297a24c71be3a70a7d0ebe153.jpgautohomecar__ChxoHmd2XHWAf2lOAAb6n2xyB8w576.thumb.jpg.7e5afeae49b5e687a484a268e99d2802.jpgautohomecar__ChxoHWd2XHWAEsD4AAaS2IfgZs8931.thumb.jpg.f1ce13dc2edbda4f21a6ff4b44d67864.jpg
Ecco il nuovo SUV a sei posti della Lynk & Co per il mercato cinese dove dovrebbe essere in vendita da marzo 2025.
Si tratta di un SUV a tre file, con dimensioni di 5240 mm di lunghezza, una larghezza di 1999 mm e un'altezza di 1810 mm e un passo di 3160 mm.
La Lynk & Co 900 utilizza la piattaforma SPA Evo per grandi veicoli ibridi elettrici.
Dentro troviamo un grande schermo da 30 pollici 6K sospeso sul cruscotto. Questo funge anche da schermo di infotainment e schermo di intrattenimento per i passeggeri. Senza cornice, consente uno schermo diviso multi-view insieme all'interazione all-in-one. C'è anche un sottile pannello di visualizzazione degli strumenti da 12,66 pollici per il conducente.
Ad alimentare l'abitacolo dell'auto ci sono due chip Qualcomm Snapdragon 8295.
Ripiegabile sul tetto per i passeggeri posteriori c'è uno schermo di intrattenimento 6K da 30 pollici. Accessibile dalla seconda fila c'è un frigorifero estraibile.
La Lynk & Co 900 è possibile sceglierla tra tre diversi propulsori. Il modello base ha un sistema PHEV basato su un motore da 1,5 T che utilizza un motore elettrico da 160 kW sull'asse anteriore e un motore elettrico da 230 kW su quello posteriore. La potenza di sistema combinata per questa versione è di 530 kW.
Gli altri due propulsori PHEV sono basati su un motore 2.0T. La prima con doppio motore che utilizza un motore elettrico da 123 kW sull'asse anteriore e un motore da 230 kW su quello posteriore, con una potenza di sistema combinata di 540 kW. Poi c'è il modello top di gamma con tre motori elettrici. Questo ha lo stesso motore elettrico da 123 kW sull'asse anteriore ma utilizza un motore elettrico da 160 kW su ciascuna delle ruote posteriori per una potenza di sistema combinata di 630 kW. La velocità massima è di 200 km/h, mentre il tempo di accelerazione da 0 a 100 km/h è di 4 secondi.
https://carnewschina.com/2025/01/03/lynk-co-900-unveiled-as-a-phev-with-up-to-630-kw-of-power/
Modificato da j
  • Grazie! 1
Sembra una GAC S7; però più lunga,  più brutta e con schermi più grandi.
  • Mi Piace 1
Riusciranno a trovare una nomenclatura decente quelli di Geely e Co?
Ormai non si capisce più niente, stesso design, stesse auto, stessi segmenti… mah
Tra l’altro lo scorso anno avevano introdotto la nuova nomenclatura Z10, Z20 ecc
Modificato da KimKardashian
  • Mi Piace 1
2 ore fa, KimKardashian scrive:
Guarda che neanche loro ci capiscono più niente.
Hanno perso il registro in cui annotavano i nomi dei modelli dentro l'archivio dove tengono i brevetti di tutti i marchi (millemila).
Sono nel panico e appioppano i nomi a caso! :si:
  • Ahah! 5
I'M IN LOVE!:pippa:
"La 6° marcia, K@zzo!"
17 ore fa, KimKardashian scrive:
Io credo che in questo ci sia lo zampino di Volvo, che ad introiare nomi e sigle è stata regina.
  • Ahah! 2
  • 2 mesi fa...
Arrivano ulteriori dati sulla 900 PHEV.
Il crossover ibrido plug-in di punta Lynk & Co 900 è stato presentato in Cina con un pacco batterie Freevoy da 52,38 kWh di CATL . Ha 280 km di autonomia elettrica in condizioni CLTC. Inoltre, l'auto può caricarsi dal 20 all'80% in 17 minuti. Questo mese, la Lynk & Co 900 entrerà nel mercato nazionale cinese.
La Lynk & Co 900 è il primo veicolo del marchio ad adottare la batteria Freevoy contenente sodio di CATL. Si tratta del pacco LFP con una capacità di 52,38 kWh. Con una carica completa, la Lynk & Co 900 può percorrere fino a 280 km in condizioni CLTC. La batteria Freevoy supporta la tecnologia di ricarica 4C. Ciò significa che la velocità di ricarica è quattro volte la capacità. Di conseguenza, la Lynk & Co 900 si carica dal 20 all'80% in 17 minuti.
La batteria Freevoy è stata sviluppata specificamente per veicoli ibridi plug-in per offrire un'esperienza "simile a BEV". Include uno "strato protettivo su scala nanometrica" e utilizza la tecnologia delle particelle di stato eccitato ad alta attività nel materiale del catodo, supportando il controllo di potenza multilivello. La batteria integra anche la tecnologia agli ioni di sodio, che le consente di scaricarsi a temperature estremamente fredde fino a -40 °C e di caricarsi in condizioni fino a -30 °C.
  • Grazie! 2
On 04/01/2025 at 15:00, Beckervdo scrive:
in Volvo hanno due bussolotti, in uno ci stanno i numeri, per decine, nell'altro qualche lettera: quando fanno un nuovo modello pescano a caso una ballotta di qua e una di là ed ecco il nome.
ai cinesi è piaciuto il rigoroso metodo scandinavo e l'hanno adottato.
  • Mi Piace 1
  • Ahah! 3
6 ore fa, Beckervdo scrive:
E come ci arrivi più a tanta tecnologia?
  • Mi Piace 2
