Cmq è un auto del 2000
Questo è quanto di + ufficiale ci sia Tratto dal sito ufficiale:
GENERAL
Curb Weight 2,750 pounds (1250kg)
Weight Distribution, F/R 40% / 60%
Fuel Capacity 19 US Gal (72 Liters)
Wheelbase 106.25 in (2700mm)
Track, F/R 68.75in (1748mm) / 67.25 in (1710mm)
Width 78.3 inches (1990mm)
Front overhang 40.6 in (1031mm)
Rear overhang 41.1 in (1045mm)
Length 188 inches (4774mm)
Height 41 inches (1041mm)
Ground clearance 4 inches (100 mm)
Trunk Space, F/R 2.65 cu ft (6253.3cc) / 2.82 cu ft (6654.4cc)
CHASSIS Space frame 4130 lightweight steel
with honeycomb composite panels
ENGINE
-Type All-Aluminum V-8 2V cam-in-block
-Displacement 7.0 liter
-Bore and Stroke 4 1/8" x 4.0" (104.8 x 101.6 mm)
-Pistons Forged
-Connecting Rods EN40B billet steel
-Crankshaft 4340 forged billet steel
-Induction system Roof intake feeding twin 80mm mass air meters feeding carbon fiber plenum. Magnesium oval bore throttle body (longitudinally mounted). Intake manifold: magnesium w/ 8 individual runners.
-Heads CNC machined all-aluminum Saleen high flow
-Valves Stainless steel with titanium retainers. Intake: 2.125" (54.0mm). -Exhaust: 1.625 " (41.3mm). Beryllium exhaust seats.
-Valve train Hydraulic roller lifter/roller rocker
-Exhaust System Stainless steel high flow with merge collector incorporating dual catalysts per cylinder bank and EGR system
-Required fuel 92 octane
-Alternator 140 Amps
-Battery 12 V
-Front Engine Accessory Drive (FEAD) Compact drive system w/side-mounted water pump
-Emission Control System OBD-II compliant, dual heated oxygen sensor per bank, high-volume EVAP system
-Fly-wheel 5.5" (139.7mm) steel 4-plate
-Fuel System High capacity returnless with 42 lb./hr. injectors
-Oil system High vacuum dry sump configuration. Capacity: 12.6 qt. (12l). Aluminum oil tank.
-Horsepower 550 hp @ 6400 rpm
-Torque 525 ft.-lbs. @ 4000 RPM
-Redline 7000 rpm
Mancano le info sulle sospensioni e i freni.....
