50230 -
Giorni Massima Popolarità
36
Tutti i contenuti di J-Gian
Credo di no, questo powertrain è pensato per i mezzi più grossi, magari un giorno lo vedremo su Civic e ZR-V, ma non è scontato nemmeno questo. E se capiterà, probabilmente succederà come su Accord, che adotta la 4a Gen, ma senza il "rapportino" per il traino.
- 55 risposte
- accord 2023
- hr-v 2021
- (e 12 altri in più)
Riporto anche qui quanto accennato nel topic della nuova CR-V, in merito alla 4a generazione del sistema i-MMD, integrandolo con un comunicato by Honda: Honda Two-Motor Hybrid-Electric System January 31, 2023 The Honda two-motor hybrid system is an innovative solution to the need for low-emissions and high fuel economy that doesn’t compromise packaging or performance The Honda two-motor hybrid system made its U.S. debut in the 2014 Accord Hybrid The new fourth-generation of the Honda two-motor hybrid system debuted in the all-new 2023 Honda CR-V and shortly thereafter, the all-new 2023 Accord Honda has sold about 300,000 cars and SUVs in the U.S. powered by the two-motor hybrid system A key step in Honda’s electrification strategy, the new fourth-generation of the Honda two-motor hybrid system maximizes efficiency without compromising a vehicle’s dynamic performance or packaging. Delivering a sportier driving experience and improved capability, this latest version of the hybrid system is available in the all-new 2023 Honda CR-V, and now Accord, which will represent about 50% of CR-V and Accord sales annually. Debuting in the 2014 Accord Hybrid, the Honda two-motor hybrid system has become smaller, lighter, more powerful and more efficient with each generation. It consists of five core components: Electric generator motor (functions as an electrical generator supplying power to the hybrid battery) Electric propulsion motor (drives the wheels directly) Atkinson-cycle gasoline engine (connected to the electric generator/starter motor functions as an electrical generator, supplying power to the hybrid battery and/or the propulsion motor) Intelligent Power Unit (IPU) (houses the battery and its controlling hardware) Power Control Unit (PCU) (the “brain” of the system controlling all hybrid functions) See below for more information on these core components. New Fourth-Generation: 2023 CR-V and Accord The first three generations of the Honda two-motor hybrid system used two electric motors mounted in-line with each other, with the generator motor connected directly to the engine, and the propulsion motor connected to the drive wheels. The new fourth-generation of the system in the 2023 CR-V and Accord works differently. The two electric motors are now side-by-side, which has multiple benefits. This configuration allows for the use of a larger and more powerful propulsion motor, which now has an increased torque output of 247 lb.-ft. (+15 lb.-ft.). It also maintains its 181 hp over a broader range of motor rpm, thereby improving response. The new propulsion motor uses new high-performance magnets that, as before, are made without heavy rare-earth metals. Internally, the motor uses a multi-ring structure that helps enable a higher peak motor speed of 14,500 rpm, an improvement of 11.5%. This higher motor speed also contributes to a higher sustained top speed capability for the 2023 CR-V hybrid models (Sport and Sport Touring) of 115 mph, 28% faster than its predecessor. The new side-by-side arrangement also enables the use of an additional direct-drive gearset with a new low-speed lockup clutch (deployed in CR-V only) allowing engine drive at urban speeds and supporting the ability for CR-V to tow up to 1,000 pounds, a first for the two-motor hybrid system. A high-speed lockup clutch is used in both CR-V and Accord, enabling a more relaxed driving environment at highway speeds by reducing engine rpm while also contributing to the new higher continuous top speeds. CR-V layout shown above The IPU and PCU were further optimized for size and efficiency. The IPU houses a 1.06 kWh battery, along with the controlling hardware, in a 24% smaller package that weighs 12% less than its predecessor. This smaller size enables CR-V and Accord hybrid models to have the same cargo space as their non-hybrid counterparts. The PCU located under the hood now features a lower profile than before, creating more room in the engine compartment for better noise management. The newest version of the two-motor hybrid system also features an all-new 2.0-liter 4-cylinder engine. With the addition of direct multistage fuel injection, the new Atkinson-cycle 2.0-liter DOHC i-VTEC® 4-cylinder increases power to 145 hp (SAE net at 6,100 rpm) and torque to 138 lb.-ft. (SAE net at 4,500 rpm) in CR-V, and 146 hp (SAE net at 6,100 rpm) and 134 lb.-ft. (SAE net at 4,500 rpm) in Accord. The changes also significantly reduce emissions, with nitrogen oxides (NOx) reduced by 22%, and total hydrocarbon (THC) emissions reduced by 24%. For the first time on CR-V, the two-motor hybrid system is available with front-wheel drive or with Honda’s Real Time AWD with Intelligent Control System™. All Accords are front-wheel drive. Two-Motor Hybrid System Fundamentals Drive Force Transfer Rather than use a torque converter or mechanical pulley or belt, the two-motor hybrid system relies on the interplay of the two motors for driving and generating power. This form of drive force transfer offers smooth and predictable acceleration matched with efficient low-rpm highway cruising when the gasoline engine is in operation. Under most circumstances, the gasoline engine connected to the generator produces electricity, which is subsequently fed through the battery, and then to the drive motor. The system is able to optimally and rapidly control both engine and electric motor rotation in order to deliver higher fuel efficiency and quicker engine response in each driving mode. In the 2023 CR-V Sport and Sport Touring, the new side-by-side arrangement of the electric motors in the new fourth-generation of the system enables an additional low-speed lockup clutch. This allows direct engine drive under a wider range of vehicle speeds. When cruising at mid- or high-speeds in the high-efficiency range of the engine, a lock-up clutch engages the drive motor to the generator motor, transmitting engine torque directly to the drive wheels as efficiently as possible. Propulsion and Generator Motors Honda’s two-motor hybrid system can operate as either a series or parallel hybrid. The majority of the time, the system operates as a series hybrid. Its electric propulsion motor drives the wheels directly, while the gasoline engine connected to the electric generator/starter motor functions as an electrical generator, supplying power to the hybrid battery and/or the propulsion motor. Under certain driving conditions, such as steady-state cruising at highway speeds, the system switches seamlessly to parallel hybrid operation, with the gasoline engine connecting to the front axle via a clutch, and vehicle speed is proportional to engine speed (rpm). During braking or when coasting, the propulsion motor converts the kinetic energy of the decelerating vehicle into electrical energy to recharge the battery. The brake system seamlessly coordinates mechanical and regenerative braking with an electric-servo braking system for natural, linear, and responsive brake performance and pedal feel. In addition to supplying electric energy to the propulsion motor, the generator motor can also be used to recharge the battery under certain conditions. The generator motor also restarts the gasoline engine when resuming travel after idle-stop has engaged. Atkinson Cycle Engines The two-motor hybrid system features a 4-cylinder engine that uses the highly efficient Atkinson cycle. The Atkinson cycle holds the intake valve open longer than normal during the compression stroke, allowing a reverse flow of intake air into the intake manifold. This allows more complete use of the energy from the combustion process, greatly enhancing efficiency. As a result, each engine paired with the two-motor hybrid system has been among the most thermally efficient gasoline engines ever used in a mass-production vehicle, with a thermal efficiency of around 40%, compared to the 25% to 30% thermal efficiency of most combustion engines. In all versions of the system powering 2014-2022 Accord and 2020-2022 CR-V, a 2.0-liter DOHC i-VTEC® engine (LFA1) is used, while the smaller Honda Insight is equipped with a 1.5-liter DOHC i-VTEC® engine (LEB-MMD). Each gasoline engine uses a high compression ratio (13.0:1 to 13.5:1 for the 2.0-liter, 13.5:1 for the 1.5-liter), but thanks to advanced combustion chamber design, precise combustion control and anti-knocking technologies, each is able to operate using regular unleaded fuel. Contributing to that efficiency and critical to the operation of the Atkinson cycle is a lightweight DOHC i-VTEC® cylinder head, with Variable Timing Control (VTC) on the intake cam used to continuously adjust the intake cam phase. i-VTEC® changes the lift profile, timing and duration of the intake valves’ operation. More information about the benefits of VTEC® is available here. In all vehicles powered by the two-motor hybrid system, the gasoline engine can be decoupled from the rest of the hybrid powertrain and operate only as needed. Depending on the state of battery charge and other parameters, it will automatically shut off during deceleration and when the vehicle is at a stop or operating under battery power. When needed, the gasoline engine restarts automatically, without action from the driver. Intelligent Power Unit The Intelligent Power Unit (IPU) houses the lithium-ion (Li-Ion) batteries. Compact and lightweight, the IPU allows for optimum placement of the batteries with minimum intrusion into the vehicle’s cargo or passenger space. The IPU also manages the battery to maintain optimal charge states over a wide variety of operating conditions. The battery is recharged by the propulsion motor operating in regenerative braking mode, and by the generator motor, which is powered by the gasoline engine. The battery powers the electric propulsion motor. Power Control Unit The “brain” of the two-motor hybrid system is the Power Control Unit (PCU). It controls all hybrid functions as it dictates the power management strategy to optimize performance. Based on driving conditions and power demand, it decides which drive mode is best and how much power from the generator should go to recharge the battery or drive the vehicle’s propulsion motor. Drive Modes Three different operating modes are used by the two-motor system, which seamlessly switches between the three depending on throttle position, state of battery charge, and other factors. EV Drive Mode – Active when starting from a stop, during light cruising and acceleration, and when braking. The gasoline engine is off in this mode and is decoupled from the drivetrain to reduce friction. Hybrid Drive Mode– The electric propulsion motor alone powers the front wheels, with the gasoline engine powering the electric generator motor, which in turn provides power to the battery pack. This either supplements the battery by providing added electrical power to the propulsion motor or charges the battery if needed. Engine Drive Mode – Under certain conditions, such as when cruising at medium to high speeds, the high-efficiency Atkinson-cycle i-VTEC® gasoline engine provides propulsion via a lock-up clutch that connects the generator motor to the propulsion motor. This effectively sends power directly from the engine to the drive wheels. All Generations and Applications First-Generation: 2014-2016 Accord Hybrid In the U.S. market, the Honda two-motor hybrid system debuted in the 2014 Accord Hybrid with a combined output of 196 hp, and EPA-estimated fuel economy rating of 49 mpg city, 45 mpg highway and 47 mpg combined . The propulsion motor linked to the drive wheels generates 166 horsepower and 226 lb.-ft. of torque. The hybrid system’s 2.0-liter i-VTEC® Atkinson cycle 4-cylinder engine puts out 141 hp (SAE net at 6,200 rpm) and 122 lb.-ft of torque (SAE net at 3,500-6,000 rpm). Located behind the rear seat, the IPU combines a 1.3 kilowatt-hour (kWh) Li-Ion battery and control hardware, along with the DC/DC converter. The PCU is located under the hood above the two-motor unit. With up to 12.7 cu.-ft. of trunk space, Accord Hybrid offered competitive cargo space for its class. Second-Generation: 2017 Accord Hybrid The second generation of the two-motor hybrid system featured more fully optimized motors. Both the generator and propulsion motors featured square copper wire and a new method of winding that increased the density factor from 48% to 60%. The result was smaller and 23% lighter motors that were nonetheless more powerful than their predecessors. In the propulsion motor, three smaller and lighter magnets were arranged in an arc to create six magnetic poles, as opposed to the two-magnet arrangement of the first generation. This new arrangement improved torque multiplication, increasing the propulsion motor’s maximum power to 181 hp, and torque to 232 lb.-ft. Power and torque also increased for the 2.0-liter engine to 143 hp (SAE net at 6,200 rpm) and 129 lb.-ft. (SAE net at 4,000 rpm), gains of 2 hp and 7 lb.-ft. Peak combined output climbed to 212 hp. When it debuted, the 2017 Accord Hybrid was the most powerful and most fuel-efficient hybrid in its class, with an EPA-estimated fuel economy rating of 49 mpg city, 47 mpg highway and 48 mpg combined. Still located behind the rear seat and containing a 1.3 kWh Li-Ion battery pack, the IPU provided the same capacity and output as before, but in a more compact and lighter package. By utilizing VDA-standard high energy density Li-Ion battery cells, unifying the battery ECU and cell voltage sensor into one component, and using a single rather than dual cooling duct, overall volume of the IPU was reduced by more than 30% from 3.32 to 2.26 cu.-ft., with a nearly 13% weight reduction, from 113.8 lbs. to 99.2 lbs. The smaller size of the IPU also helped increase trunk capacity to 13.5 cu.-ft. Likewise, the PCU was upgraded with a new design that reduced the component weight by 27% and reduced its size by 23%. Additional size and weight was saved by mounting the PCU directly to the two-motor unit, reducing the number of components compared to the previous two-motor system by eliminating the mounting bracket. Third-Generation: 2018-2022 Accord Hybrid More refined and compact, the third-generation of the two-motor system debuted in the 2018 Accord Hybrid with EPA-estimated fuel economy rating of 48 mpg city and 47 mpg for highway and combined. The IPU was again reworked, making it 32% smaller than its predecessor. Part of the size reduction came from relocating the DC/DC converter from the IPU as it was in earlier versions of the two-motor hybrid system, to the PCU mounted above the transmission. By shrinking the IPU, engineers were able to relocate the unit under the rear seat base instead of the trunk giving Accord Hybrid the same roomy trunk and 60/40 split-folding rear seatback versatility of the non-hybrid Accord models. Along with the size reduction, the new IPU features improved battery control systems and revised battery chemistry, allowing it to operate over a broader state-of-charge range for improved efficiency. The 2.0-liter gasoline engine features a slightly higher compression ratio (13.5:1), which resulted in moving the torque peak of 129 lb.-ft. (SAE net) from 4,000 rpm down to 3,500 rpm while maintaining a horsepower peak of 143 hp at 6200 rpm (SAE net). Based on a proprietary, jointly patented Honda and Daido Electronics design, the system’s two next-generation electric motors were upgraded with new permanent magnets with no heavy rare-earth metals. Peak output remains at 181 horsepower and 232 lb.-ft. of torque. To give the driver more control over electric regeneration, Accord Hybrid includes steering wheel-mounted selector paddles that allow the driver to choose between four levels of regenerative braking performance. Third-Generation: 2019-2022 Insight Though based on the third-generation two-motor hybrid system found in Accord, Insight used components optimized for the smaller compact sedan. Insight used a 1.5-liter DOHC i-VTEC® 4-cylinder Atkinson-cycle engine, putting out 107 hp (SAE net at 6,000 rpm) and 99 lb.-ft. of torque (SAE net at 5,000 rpm). In addition to the regen paddles from Accord, Insight featured a “click point” at roughly the three-quarter-point of pedal travel. Drivers could push past the “click point” to deliver full power from the engine and electric motor for maximum acceleration, regardless of driving mode. The propulsion and generator motors were less powerful than those found in Accord, but feature similar square-wire, winding, and rare-earth-metals-free magnet technologies. The propulsion motor was rated at 129 horsepower and 197 lb.-ft. of torque. Combined total output for the system was 151 horsepower, and Insight achievedup to an EPA-estimated fuel economy rating 55 mpg city, 49 mpg highway and 52 mpg combined. Insight’s compact IPU with its 1.2 kWh battery was positioned under the rear seat base, giving it the same roomy trunk and folding rear seatback versatility of a conventional non-hybrid sedan. The PCU was mounted in the engine compartment above the two-motor assembly and includes the DC/DC converter. Third-Generation: 2020-2022 CR-V Hybrid The first-ever hybrid SUV from Honda, CR-V Hybrid used a two-motor hybrid system based on the system utilized by the Accord Hybrid, and combined it for the first time with an all-wheel drive system. CR-V Hybrid was the most fuel-efficient CR-V ever, with an EPA-estimated fuel economy rating of 40 mpg city, 35 mpg highway and 38 mpg combined. With a combined output of 212 horsepower, it was also the most powerful CR-V ever when it was introduced. Similar to Accord Hybrid, the 2.0-liter DOHC i-VTEC® 4-cylinder Atkinson-cycle engine developed a peak 143 hp (SAE net at 6,200 rpm) and 129 lb.-ft. of torque (SAE net at 3,500 rpm. The propulsion motor was rated at 181 hp and 232 lb.-ft. of torque. To give the driver more control over electric regeneration, CR-V Hybrid also included the steering wheel-mounted selector paddles introduced with Accord Hybrid. For CR-V Hybrid, the IPU with its 1.4 kWh battery was located below the cargo floor, giving it similar cargo utility and the same 60/40-split dive-down and fully-flat folding second-row seats as the non-hybrid CR-V. As with Accord Hybrid, the DC/DC converter was integrated with the PCU in the engine compartment. CR-V Hybrid was the first Honda model using the two-motor hybrid system to feature Real Time AWD with Intelligent Control System™. The compact and efficient system was entirely mechanical to provide a high degree of control and driving confidence in rain, snow, dirt roads and on dry pavement. A multi-plate clutch connected the propeller shaft to the rear differential and was engaged by a hydraulic pump operated by an electric motor. The system minimized wheel spin under acceleration by proactively sending power to the rear wheels. When AWD was not required, such as when cruising, all drive force was sent to the front wheels to increase efficiency. Honda Two-Motor Hybrid Applications 2-Motor Hybrid System Model Gasoline Engine (Atkinson Cycle) Propulsion Motor Combined System Horsepower EPA-Estimated Fuel Economy (City/Highway/Combined)2 1st gen 2014-2016 Accord Hybrid 2.0-liter i-VTEC® 141 hp @ 6200 rpm 122 lb.-ft. @ 3500-6000 rpm 166 hp 226 lb.-ft. 196 hp 49 / 45 / 471 2nd gen 2017 Accord Hybrid 2.0-liter i-VTEC® 143 hp @ 6200 rpm 129 lb.-ft. @ 4000 rpm 181 hp 232 lb.-ft. 212 hp 49 / 47 / 48 3rd gen 2018-Present Accord Hybrid 2.0-liter i-VTEC® 143 hp @ 6200 rpm 129 lb.-ft. @ 3500 rpm 181 hp 232 lb.-ft. 212 hp (202 using ISO standard) 48 / 47 / 473 44 / 41 / 434 3rd gen 2019-2022 Insight 1.5-liter i-VTEC® 107 hp @ 6000 rpm 99 lb.-ft. @ 5000 rpm 129 hp 197 lb.-ft. 151 hp 55 / 49 / 525 51 / 45 / 486 3rd gen 2020-2022 CR-V Hybrid 2.0-liter i-VTEC® 143 hp @ 6200 rpm 129 lb.-ft. @ 3500 rpm 181 hp 232 lb.-ft. 212 hp (202 using ISO standard) 40 / 35 / 38 4th gen 2023-Present CR-V 2.0-liter i-VTEC® 145 hp @ 6100 rpm 138 lb.-ft. @ 4500 rpm 181 hp 247 lb.-ft. 204 hp (using ISO standard) 43 / 36 / 40 4th gen 2023-Present Accord 2.0-liter i-VTEC® 146 hp @ 6100 rpm 134 lb.-ft. @ 4500 rpm 181 hp 247 lb.-ft. 204 hp (using ISO standard) 51 / 44 / 483 46 / 41 / 446 1 Calculated using more stringent ratings enacted by the U.S. EPA for the 2017 model year. Original EPA rating 50/45/47 2 Based on 2022 EPA mileage ratings; Use for comparison purposes only; your mileage will vary depending on how you drive and maintain your vehicle, driving conditions, and other factors 3 Hybrid, EX-L 4 Sport, Touring 5 EX 6 Touring Fonte: https://hondanews.com/en-US/honda-automobiles/releases/release-1503019bd8a757ea08267d7944378955-honda-two-motor-hybrid-electric-system
- 55 risposte
- accord 2023
- hr-v 2021
Una cosa che ci siamo fatti sfuggire, è che questa CR-V 2023, assieme alla nuova Accord 2023, montano la 4a generazione del sistema i-MMD. Cambia il layout interno, dove motore elettrico e generatore, non sono più coassiali, ed hanno design e caratteristiche un po' diversi (vedi tabella sotto). Ma la cosa che più salta all'occhio (e pare sia limitata a CR-V, quindi non ad Accord), la presenza di un secondo sistema di lock-up per collegare meccanicamente il motore endotermico alle ruote, con un rapporto di riduzione maggiore. Questa scelta fa sì che la trazione elettrica possa essere bypassata, in alcune circostanze, anche a velocità medio basse, ottimizzando i consumi e soprattutto le capacità di traino, che nel caso della CR-V può arrivare a 750 kg (frenati). Il secondo sistema di lock-up invece, è ora adatto a funzionare a velocità più elevate, ottimizzando ulteriormente i consumi a quelle velocità (simile ad una 7a marcia). 3rd gen. 4th gen. Internal combustion engine power 107 kW 108.2 kW Internal combustion engine torque 175 Nm 187 Nm Traction motor power 135 kW 135 kW Traction motor torque 315 Nm 335 Nm Maximum electric motor speed 13000 14500 Generator power 106 kW 120 kW Generator torque 85 Nm 68 Nm Maximum generator speed 13000 19000 @Wilhem275, @Matteo B.
- 51 risposte
- 10
Nell'uso che si fa delle auto, comunque, carichi motore e regimi di funzionamento, anche nelle ibride, sono quasi stazionari: variano meno, ma variano molto più di quanto si possa immaginare. Ecco, magari hai un bel vantaggio in accelerazione, dove le condizioni di caric/regime restano molto più regolari rispetto ad una'uto con cambio non "CVT", che deve spazzolare più regimi e condizioni di funzionamento. Ed in generale, si cerca di mantenere la condizione che minimizza il consumo istantaneo, più che il rendimento. Ovvero, raramente porti il motore nella condizione di massima resa, se quella condizione ti porta a produrre più potenza di quella che ti serve, altrimenti avresti un consumo istantaneo più alto di quanto richieda la situazione. Ci sono auto elettriche con cambio (solitamente 2 rapporti), es. il motore posteriore di Taycan (forse anche le Rimac), oppure alcune PHEV, tra cui VAG e Hyundai/Kia . Ma in generale un motore elettrico ha un buon rendimento e caratteristiche di funzionamento omogenee lungo tutto l'arco di funzionamento (regimi-carico), quindi il cambio lo usi solo in situazioni particolari, es. vuoi raggiungere una velocità particolarmente elevata, oppure nelle competizioni, o ancora, nelle situazioni in cui ti ritrovi già un cambio tra i piedi, come nelle PHEV (su cui comunque non si usano tutte le marce).
- 257 risposte
- mazda elettrica
- mx-30 2020
- (e 9 altri in più)
Tutto sommato ce la vedrei bene anche in EU, ma non penso accadrà
Diciamo che è da usare quanto più possibile in EV, ed in modalità normale può avere un ottimo range in un contesto urbano/ suburbano. In autostrada, non è un sistema efficiente, trovi crossover a benzina che fanno molto meglio. A tutti gli effetti, è un piccolo SUV elettrico, con cui puoi star tranquillo di non rimanere fermo perché è finita la carica. Ci sta, una soluzione un po' esotica che non mi dispiace. Comunque sono auto molto differenti, considerando il pochissimo spazio che ha nei posti dietro la Mazda.
- 257 risposte
- mazda elettrica
- mx-30 2020
Pensa se scopriamo che consumano meno la Honda? 🤣
- 257 risposte
- 2
- mazda elettrica
- mx-30 2020
Se non sbaglio Honda ha un sistema concettualmente più simile a Mazda, ma a pistoni: CRV PHEV https://it.motor1.com/reviews/686574/honda-crv-2023-prova-video/
- 257 risposte
- mazda elettrica
- mx-30 2020
Una volta visti i risultati, sarei poi curioso di vedere questo sistema replicato su una macchina "elettricosa" più grossa 😅
- 257 risposte
- mazda elettrica
- mx-30 2020
Tocca "ibernarli" assieme al terreno però
- 31 risposte
- airbus
- airbus a320
(e 3 altri in più)
In effetti, per fare una cosa fatta bene, dovrebbero dichiarare il dato in litri/ora (o almeno le condizioni di contorno), perché un conto è avere un certo consumo ad alta velocità, un altro è avere lo stesso consumo a bassa velocità, o da fermi. Vale per tutte le PHEV con funzione autoricarica. Anzi, imho dovrebbero dichiarare anche il WLTP in modalità ibrida (sia esso a batteria scarica, o in condizione di buffer minimo)... Vuoto legislativo.
- 257 risposte
- mazda elettrica
- mx-30 2020
Ecco, non sapevo di questa convenzione, se confermata diventa più interessante! Non è una garanzia, se un marchio sparisce, lato recupero ricambi può essere una guerra. Ad esempio, al giorno d'oggi, se hai una Saab o una Chevrolet, trovi molta ricambistica di concorrenza per le parti riguardanti manutenzione ordinaria, ma se devi cercare un ricambio un po' più specifico... Piangi 😅 In un settore in così rapida evoluzione, come l'elettrico, mi aspetto possa essere solo che più complesso. Io fatico a non tener conto di queste cose, lavorando in questo settore poi... 🙊
- 108 risposte
- smart 1
- zeekr ufficiale
(e 7 altri in più)
Non proprio (almeno per ora), vedi anche ciò che sta succedendo con Infiniti e Nissan: non è che quest'ultimi ti accettino le auto Infiniti come fossero le loro (per le garanzie poi, non esiste proprio); se te le pigliano su, è perché hanno anche l'officina per altri marchi e te la trattano come un'altra auto X.
- 108 risposte
- smart 1
- zeekr ufficiale
(e 7 altri in più)
Per quanto di base sia vero che sfruttamenti estremi della batteria non siano il massimo, su un'elettrica non dovrebbe essere un problema. Su quest'auto, da ciò che ho capito, la questione riguarda l'utilizzo che se ne vuole fare. In pratica, la situazione in cui mantiene la carica al 45-50%, è il funzionamento in modalità Normal, che ti permette di estendere l'autonomia complessiva dell'auto, senza uccidere la media dei consumi di carburante. In questa modalità, dopo averla usata in EV, arrivati al 45% di carica, il frullino si accende per lavorare nelle condizioni ottimali ed alza il regime solo a velocità stradali medio alte, cercando di mantenere il buffer di carica attorno al 50% e di non consumare troppo carburante (un po' ciò che fanno Honda e Nissan, ma senza avere una batteria così capiente). Sarebbe un po' la modalità che useresti per farti 300 km se sai che non hai possibilità di effettuare ricariche intermedie. Poi c'è la modalità EV che sfrutta il più possibile la batteria. È quella che useresti se sei sicuro che la ricarica ti basti nel viaggio che hai in mente di fare e poi puoi ricaricare. Ma se l'autonomia EV non dovesse bastare, l'accensione del frullino avverrebbe solamente come "toppa" per raggiungere una colonnina. In questa situazione, il frullino funzionerà anche a regimi/carichi piuttosto elevati, potendo contare su un apporto elettrico della batteria praticamente nullo. Ovviamente berrà come una mucca assetata, ma poco guasta, se hai in mente di fare pochi km e poi ricaricare. Infine, c'è la modalità Recharge, che attivi solo se sei pirla se sei a corto di autonomia EV, ma magari hai in vista un accesso ad una zona ZTL: usi il frullino per ricaricare la batteria strada facendo (quindi non solo per generare lo stretto necessario) e svuoti barili di benzina, creando una cappa di CO2, che il metano spostati...
- 257 risposte
- mazda elettrica
- mx-30 2020
Sembrano delle belle auto e negli anni hanno indubbiamente fatto dei passi avanti nell'automotive, per non parlare della tecnologia sull'elettrico. Quello che mi chiedo in questo momento, è se siano in grado di fornire già da ora un'assistenza adeguata. E soprattutto, per quanto tempo saranno in grado di fornirla nel tempo (es. marchio che chiude, cambia nome, ecc.)
- 108 risposte
- smart 1
- zeekr ufficiale
(e 7 altri in più)
Che tipo di batteria monta questa?
- 97 risposte
- toyota bz4x concept
- toyota ufficiale
- (e 13 altri in più)
Un po' è una caratteristica dell'auto, ma se hai notato differenze marcate rispetto all'inizio, potresti avere problemi all'assetto, o peggio, dei giochi/laschi dovuti all'usura della tiranteria, o fissaggi della scatola sterzo. A volte potrebbe esserci anomalie alla servoassistenza, ma quella di solito viene meno, quando ci sono problemi. Nel dubbio, portala da un gommista e fai fare un controllo assetto (ed eventuale correzione) e verifica tiranterie.
Tassazione esclusa, immagino?
- 23 risposte
I motivi per cui non si comprano auto elettriche penso siano molti, a partire dal prezzo, incertezza generale dovuta a mancanza d'infrastrutture e di esperienza, o banalmente il "restare in attesa" per capire l'evoluzione di questi nuovi mezzi e decisioni dall'alto. Se però vuoi un'auto elettrica di medie dimensioni, effettivamente, in questo momento, la cosa più sensata è prendere una Tesla: lato powertrain sono il top, rete supercharger strategicamente collocata, una community con molta esperienza. Abbiamo visto che hanno anche più di qualche difetto, che - personalmente - non potrei tollerare, ma un "entusiasta" di questa nuova tipologia di mezzi, come si è visto, può soprassedere, magari lusingato dall'innovativa rete di assistenza. Quindi io direi che di auto elettriche se ne vendono poche per svariati motivi, ma se vuoi un'elettrica, hai un ventaglio di ragioni per preferire Tesla. PS. L'unico altro modello che vedo sensato, è la 500e. Ma solo se vuoi un'auto compatta e sfiziosa, senza ambire ad un utilizzo per lunghe trasferte. In effetti, anche 500e è unica nel suo genere.
- 36 risposte
- 2
- vendite
- auto elettriche
(e 1 altro in più)
Il processore del 12T pro è lo stesso che avevo sull'Edge 300 Ultra: veramente un processore molto riuscito, potente e parco nei consumi. Poi è vero, lo schermo piatto è un qualcosa che tutt'ora mi manca... Non capisco veramente il senso di fare lo schermo curvo, più scomodo da usare, ti ruba angolo visuale, ed espone il telefono agli urti.
Vista dal vivo: per quanto non abbia mai avuto simpatia per l'estetica di questo mezzo, devo dire che per quest'ultima versione hanno fatto davvero un bel lavoro. Nelle versioni con i sedili elettrici, si può regolare anche l'inclinazione della seduta. Promossa per me. Attendiamo i listini... 😣
- 71 risposte
- toyota c-hr 2023
- c-hr
(e 4 altri in più)
Vista dal vivo durante un'esposizione in città: veramente un bel macchinone, non originale come linea, ma pur sempre un gradevole elettrodomestico, con un ottimo sistema ibrido e molto spazio a bordo. Se non fosse per la garanzia estesa della Toyota, preferirei CR-V al Rav 4. In ogni caso, il problema principale, resta il prezzo, ormai veramente fuori dalla portata di uno stipendio medio. Io non me la sento d'investire queste cifre in un qualcosa che si deprezza e rischia di essere distrutto al minimo errore... Non so voi?
- 51 risposte
- 4
Ho avuto modo di salirci ieri ed è stata un po' una delusione: l'auto è gradevole alla vista, ma dalle foto mi ero fatto l'idea di un salto di qualità degli interni notevole... Invece, pur con molti particolari tendenti all'opulenza, ha tantissime plastiche e pulsantiere terribili per il livello dell'auto. Nello specifico, le plastiche laterali del tunnel, sono roba da segmento B. Idem alcuni pulsanti nero lucido, che non sembrano nemmeno allineati al piano orizzontale. Su piano black stendiamo un velo pietoso... Insomma, avevano fatto 27, non mancava poi così tanto a fare 30.
- 394 risposte
- trailhawk
- grand cherokee 2022
- (e 8 altri in più)
Android "near stock" per me è quasi il massimo, tanto più se arricchito dalle altre funzioni complementari by Motorola. Non ho mai provato quel telefono, ma ricordo con piacere l'Edge 30 Ultra
