Mostra i risultati del/dei TAG ''audi tecnologia'' .
Trovato 22 risultati
The MQ281 has a torque spectrum of 200 to 340 N·m, which means it completely or partially supersedes the current Volkswagen gearbox designs with the internal designations MQ250 and MQ350 respectively. The MQ281 is based on a 2.5 shaft concept and boasts a high gear spread of maximum 7.89. On the one hand, this guarantees good driving off performance—even for heavy vehicles with large wheels—and facilitates, on the other hand, downspeeding, which is (fuel-saving) driving in high gears with low engine speed. Development of the new gearbox focused primarily on improving efficiency. Here we employed virtual development methods. This enabled us to design a completely new oil conduction system. Using a variety of oil conduction measures, we are able to achieve a uniform and optimum lubrication of gear wheels and bearings, reducing the amount of lifetime oil required to just 1.5 liters. —Helmut Göbbels To further reduce friction, a bearing concept adapted to the gearbox was developed. The design used friction-minimized bearings with low-contact seals. Material use and its distribution for the gearbox housing was also optimized. With the aid of a further virtual development tool, a strength-optimized housing structure could be designed. The new housing supports the noise requirements of today (avoidance of undesired secondary noises) and therefore ensures improved driving comfort through less audible and noticeable vibrations in the vehicle. As is the case with many Volkswagen gearboxes, the MQ281 is produced in-house. SEAT Componentes, together with Martorell and Barcelona, one of the three production centers for the Spanish brand and simultaneously part of the production portfolio for Group Components, has started production of the new MQ281 gearbox. Up to 450,000 units can be built per year. Re-sorting gearbox production goes hand-in-hand with the production start of the new MQ281. While the new six-speed gearbox is being produced in El Prat de Llobregat and Córdoba (Argentina), the MQ200 manual gearbox has been primarily relocated to ŠKODA Components in Mlada Boleslav (Czech Republic). At the same time, the component plant in Kassel is concentrating on the production of the dual clutch gearbox DSG, and above all on the production of the electric drive for future vehicles built on the MEB platform. SEAT Componentes is a key plant for our company and, with the assignment of this project, for the Volkswagen Group as well. With these new gearboxes, we can increase maximum production to up to 3,500 units per day and use the facility as a reference center for efficiency, productivity and quality. —Dr Christian Vollmer, SEAT Vice President of Production and Logistics
- 4 risposte
- 2
- volkswagen mq281
- volkswagen
- (e 8 altri in più)
VAG EA288 EVO: il nuovo 2.0 TDI del gruppo Volkswagen
nella discussione ha aggiunto Beckervdo in Innovazione Meccanica
Volkswagen presenta al Wien Symposium il suo nuovo EA288 EVO da 2.0 litri. Il nuovo propulsore sostituisce il 1.4 TDI, il 1.6 TDI ed il precedente 2.0 litri TDI. Con potenze che vanno da 100 kW (136 CV) fino a 150 kW (204 CV), mentre la coppia è aumentata del 9% (in media) su tutte le potenze disponibili. L'unità da 204 CV eroga 400 Nm di coppia costanti tra 1750 e 3000 rpm. A dare manforte all'unità termica ci pensa un sistema elettrico a 48V con una piccola batteria agli ioni di litio. Rivista completamente la linea di scarico, con il DPF posizionato più vicino allo scarico del turbocompressore (anch'esso revisionato) ed una nuova gestione della valvola EGR per garantire il rispetto delle normative Euro6D-Temp con i cicli WLTP e RDE. I primi modelli che lo utilizzeranno saranno a marchio Audi (longitudinali), mentre per l'installazione trasversale debutterà prima su Volkswagen, poi Seat ed infine Skoda. Via Autoforum.cz- 35 risposte
- meccanica auto
- innovazioni auto
- (e 13 altri in più)
VAG: abbandono del motore diesel sotto i 2.0 di cilindrata?
nella discussione ha aggiunto gpat in Notizie e Scelte Strategiche dal mondo dell'Auto
Il 1.5 TDI a oggi.. non esiste- 60 risposte
- 3
- meccanica auto
- innovazioni auto
Audi - Duos: propulsore a cilindri di sezione differente
Prendete quello che scrivo con le pinze, dato che l'ho trovato solo in un sito olandese. Audi avrebbe brevettato questa nuova architettura modulare che chiama DUOS. Praticamente - raffigurato - un quattro cilindri che presenta due coppie di cilindri dall'alesaggio differente. Presumibile per alti e bassi carichi. Per passare da un funzionamento all'altro si utilizza un secondo albero motore che tramite una camma attiva e disattiva il moto di metà motore. Via Autoblog.nl- 8 risposte
- 2
- meccanica auto
- innovazioni auto
(e 4 altri in più)
Audi "corre ai ripari" e mette il turbo-elettrico al suo 2.9 V6 (by Porsche, NdR) che andrà ad avere così prestazioni sovrapponibili al 4.0 V8 TFSI. Il nuovo V6, evoluzione del precedente, guadagna il sistema elettrico a 48V che muove un elettrocompressore ed un ISG. Rispetto al V6 3.0 litri della S5 - ad esempio - il nuovo V6 2.9 TFSI EVO pesa appena 21 kg in più, ma ha il comparto elettrico, un altro turbocompressore ed un elettro compressore. Questo signore potrebbe esser girato sulla R8... Via Autoforum.cz
- 4 risposte
- 7
- meccanica auto
- innovazioni auto
- (e 10 altri in più)
Audi - Trazione integrale Quattro Ultra
nella discussione ha aggiunto J-Gian in Innovazione Meccanica
Quando parliamo di Quattro associato al marchio Audi, abbiamo tutti chiaro in testa che stiamo parlando di trazione integrale. Come gli appassionati ben sanno, non tutte le "Quattro" sono uguali. Nei modelli con meccanica trasversale (A1, A3, Q3) l'integrale consiste nella classica trazione anteriore il cui moto viene indirizzato all'occorrenza anche alle ruote posteriori, tramite un sistema di frizioni servo attuate. Per quanto riguarda la gamma dotata di motori e trasmissioni a disposizione longitudinale (da A4 in su) invece, negli anni vi è stata un'evoluzione più interessante: siamo passati dal differenziale centrale autobloccante di tipo Torsen, ad un più recente sistema meccanico a lamelle, fino ad arrivare alla nuova Quattro Ultra. Con la denominazione Ultra, s'intende sostanzialmente la versione "on demand" della trazione integrale per powertrain longitudinali. Il cuore è un giunto centrale a frizioni multiple, gestite da un attuatore elettrico, capace di inviare fino al 50% della coppia disponibile alle ruote posteriori. La particolarità però sta nel retrotreno, dove troviamo un differenziale di tipo aperto contenente una frizione a denti: essa è in grado di sconnettere l'albero di trasmissione quando non necessario, minimizzando le perdite di trascinamento quando l'integrale non è necessaria, un sistema simile alla versione più avanzata della Jeep® Active Drive II. I vantaggi apportati da questo sistema, si traducono principalmente nella riduzione dei consumi quando la trazione integrale non è richiesta, quantificabile secondo Audi in 0,3 litri ogni 100 km. Il sistema inoltre pesa 4 kg in meno del precedente e permette una più efficiente interazione con l'impianto frenante, facilitando l'inserimento in curva e l'indirizzamento della potenza tra ruote interne ed esterne alla curva stessa. I tempi d'intervento sono quantificabili in poche decine di millisecondi, ma a seconda del programma di guida scelto (tramite il Drive Select) il sistema può rendere disponibile l'integrale ancor prima che la stessa si riveli necessaria per problemi di aderenza. Nelle altre situazioni, la centralina gestirà la trazione Quattro Ultra tenendo in considerazione numerosi parametri attinenti la dinamica, quali velocità delle singole ruote, accelerazione laterale, angolo volante, angolo d'imbardata, erogazione motore e persino l'eventuale presenza di un rimorchio. Autopareri J-G- 27 risposte
- haldex
- quattro ultra
- (e 9 altri in più)
Un'altra applicazione del compressore elettrico, sul V6 TDI di Audi: ai bassi regimi lavora l'elettrico, poi arriva (con comodo ) l'azione del turbocompressore classico Riporto una parte dell'articolo: Articolo completo su: Audi A6 V6 TDI electric biturbo - Come va il motore con turbo elettrico - Quattroruote
- 24 risposte
- vag tecnologia
- v6 tdi electric biturbo
- (e 7 altri in più)
Audi TT Clubsport Turbo Concept 2015
Autoweek.nl Concept Audi per Wörthersee, equipaggiato con il 2.5 TFSI portato a 600 CV e 650 Nm di coppia. 0-100 in 3,6 secondi e peso di 1396kg!- 18 risposte
- audi
- audi concept
[AUDI] Nuovo 2.0 TFSI 140 kW (190 hp)
nella discussione ha aggiunto AleMcGir in Innovazione Meccanica
https://www.audi-mediaservices.com/publish/ms/content/en/public/pressemitteilungen/2015/05/07/world_premiere_at.html- 14 risposte
- 2.0 tfsi 190 cv
- 2.0 tfsi 2015
(e 3 altri in più)
Audi - Brevetto motore a compressione variabile
Fallita Saab, Audi deposita il brevetto di un sistema a compressione variabile che ricorda moltissimo il sistema SVC (Saab Variable Compression) Via Autoblog.nl- 27 risposte
- audi tecnologia
- compressione variabile
- (e 3 altri in più)
[Porsche-Audi] MSB VS MLB Evo
nella discussione ha aggiunto Touareg 2.5 in Notizie e Scelte Strategiche dal mondo dell'Auto
WCF Classica scena di famiglia : Porsche si lamenta che Audi abbia rifiutato la loro Modular Standard Platform per future A6, A7 e A8 e dal canto suo critica aspramente la MLB Evo di Audi, tacciata di avere un sistema di sospensioni non all'altezza, di non essere molto flessibile ed inadeguata ai nuovi sistemi elettronici. In Lamborghini stanno addirittura pensando ad una propria struttura in fibra di carbonio. Mamma Volkswagen corre ai ripari riprendendo sia Porsche che Audi, incitando al lavoro di gruppo . Mi sembrano le liti tra i miei figli, giuro.- 7 risposte
- audi mlb
- audi tecnologia
- (e 6 altri in più)
Audi - nuovo V6 TDI Clean Diesel 3.0 litri Euro 6 e DSG7 longitudinale per trazioni anteriori
The new V6 diesel features a number of advanced technologies. The piston rings and pins have been optimized for minimal friction. The crankcase and the newly designed cylinder heads have separate coolant loops. The updated, innovative thermal management system improves efficiency even further. The turbocharger and the fully variable‑load oil pump have also been updated.Also, for the first time, a NOx storage catalytic converter has been combined with a diesel particulate filter and SCR injection in a single assembly. The exhaust gas after‑treatment integrated into the engine package satisfies the most stringent of emissions legislation, including the Euro 6 standard. It also reduces CO2 emissions by an average of 15 grams (24.1 g/mi). The Audi lineup offers a broad choice of diesel engines with four, six and eight cylinders. It begins with the 1.6 TDI, includes the 2.0 TDI and 3.0 TDI, and tops out with the 4.2 TDI producing 283 kW (385 hp) and 850 N·m (626.9 lb‑ft) of torque in the Audi A8 [7.4 l/100 km (31.8 mpg US), 194 g CO2 per km (312.2 g/mi)]. All of these engines combine ample power with efficiency, particularly in the 13 ultra models currently available. The Audi A4 1.6 TDI ultra, for example, consumes on average just 3.2 liters of fuel per 100 kilometers (73.5 mpg US) [85 grams CO2per km (136.8 g/mi)]. These same figures for the A4 2.0 TDI ultra are 4.0 liters per 100 kilometers (58.8 mpg) [104 grams CO2 per km (167.4 g/mi)] and for the A6 2.0 TDI ultra with S tronic 4.4 liters per 100 kilometers (53.5 mpg) [114 grams CO2 per km (183.5 g/mi)]. Audi honored a small tradition with its presentation of the new 3.0 TDI engine at the Symposium; the company presented its five‑cylinder TFSI engine here in 2009 and in 2010 the (at that time) new 3.0 TDI. The premieres of the 3.0 TDI biturbo and the new 1.8 TFSI followed in 2011. Audi presented the 4.0 TFSI in 2012, and the company first presented the V6 TDI for the Audi R18 e‑tron quattro race car to the public at the 2013 Vienna Motor Symposium. Besides the new 3.0 TDI, Audi is also presenting another innovation in Vienna: a new seven-speed dual‑clutch transmission for models with longitudinal engines and front‑wheel drive. The latest-generation S tronic is extremely sporty, yet very comfortable. The newly developed dual-clutch transmission reduces CO2 emissions by as much as 10 grams per kilometer (16.1 g/mi). Via GreenCarCongress Dopo il V6 BiTDI ed il V6 TDI Electric BiTurbo...arriva l'evoluzione per il 3.0 litri monoturbo, con norma Euro6 e per la prima volta con convertitore catalitico, DPF e filtro SCR tutto in un unico comparto (sai che gioia). Evoluzione che si porta dietro - finalmente - l'abbandono della trasmissione Multitronic per l'utilizzo di un nuovo 7 marce per motori longitudinali e trazione anteriore.- 26 risposte
- audi tecnologia
- 3.0 tdi
(e 1 altro in più)
Audi - Nuove molle leggere in polimeri e fibra di vetro
nella discussione ha aggiunto boygrunge in Innovazione Meccanica
Nuove molle leggere in polimeri e fibra di vetro Audi - Nuove Molle Leggere In Polimeri E Fibra Di Vetro - Quattroruote Mi chiedevo: e per smaltirle? l'acciaio dovrebbe essere riciclabile al 100%, a differenza di resine&Co. In generale: oltre all'importanza dell'innovazione, i benefici saranno davvero reali, soprattutto su berline da 16-17 q.li, con automatico e dieselozzo?- 20 risposte
- audi
- audi tecnologia
(e 2 altri in più)
Audi - Cruscotti sempre più intelligenti
nella discussione ha aggiunto nucarote in Automazione, Entertainment e Sicurezza
Dashboard gauges are so 20th century. The dash of the future is a flat, high-resolution, and fully customizable. And that’s what the next Audi TT will have when it lands in showrooms later this year. At CES Audi showed off a full-sized mockup of the TT’s new interior, and the crown jewel is a 12.3-inch LCD screen behind the steering wheel that can toggle between a traditional tachometer and speedometer and a massive map with infotainment and navigation displays flanked by small virtual gauges. Inputs are handled through Audi’s next-generation Multi-Media Interface control knob mounted behind the stick. It has fewer buttons but gets the latest iteration of Audi’s touchpad that allows you to write characters with your finger rather than endlessly scrolling through the alphabet. The other notable bit is the removal of the traditional climate controls in the center console. Instead, the driver and passenger can change the interior temperature by twisting a knurled metal knob in the center of the vents, complete with a TFT display showing the fan speed and air temp. Audi's New Dashboard Gives Us Beautiful Information Overload | Autopia | Wired.com E dopo aver quasi smesso di guardare il lunotto e gli specchietti per far retromarcia, il prossimo passo sarà quello di guardare il parabrezza quando si guida.- 1 risposta
- audi tecnologia
- display
(e 2 altri in più)
VAG (Audi) - Nuova versione 1.8 TFSI
nella discussione ha aggiunto simonepietro in Innovazione Meccanica
In uscita a breve su A4 e A5 . Il lancio del nuovo motore 1.8 TFSI l segna la terza generazione di questa fortunata famiglia di quattro cilindri usata da Audi. E 'stato completamente rivisto, al fine di raggiungere gli ambiziosi obiettivi di emissioni di CO2 e garantire la sua conformità con le future norme sulle emissioni Euro 6. La nuova generazione offre numerose tecnologie innovative, tra cui un sistema di raffreddamento dei gas di scarico integrato nella testa del cilindro, un sistema a doppia iniezione con iniezione diretta e indiretta , così come il sistema Audi valvelift su entrambi gli asse a camme. Una gestione completamente elettronica del sistema di raffreddamento . Il nuovo 1.8 TFSI ,da 125 kW di potenza e 320 Nm di coppia , emette livelli di CO2 inferiori fino al 22% rispetto alla uscente uscente versione da 118kW / 250Nm . Il raggiungimento di questi obiettivi ha imposto l'aggiunta di un carico di tecnologia, addirittura due sistemi di alimentazione ad iniezione ed un sistema integrato a livello di collettore di scarico. Il dottor Thomas Heiduk, ha dichiarato: "Al fine di ottemperare alle future norme sulle emissioni, abbiamo scelto di utilizzare due distinti circuiti di alimentazione. Così all' l'iniezione diretta abbiamo aggiunto anche l'iniezione indiretta. Quest'ultima viene utilizzata a carico parziale, offrendo una riduzione delle emissioni e una migliore efficienza . " Il sistema di iniezione diretta con pressione a 200 bar ,viene utilizzato durante l'avviamento del motore e con elevati carichi di potenza , mentre il sistema di iniezione indiretta viene utilizzato a carichi parziali dato che offre una migliore formazione della miscela in tali condizioni , inoltre riduce al minimo le emissioni di particolato. L'efficienza è migliorata anche grazie all'adozione , prima applicazione su un Audi ,di un collettore di scarico raffreddato ad acqua. Questo aiuta a ridurre il peso e riduce i tempi di entrata in temperatura del motore . " il nuovo collettore di scarico permette di fare a meno dell' arricchimento a pieno carico e in tal modo il consumo di carburante può essere ridotto significativamente," parole di Heiduk. Il circuito di raffreddamento stesso è stato ridisegnato. La gestione termica non avviene più tramite un termostato, ora la pompa dell'acqua e due valvole elettromeccaniche sono gestite elettronicamente . Il turbocompressore è fornito dalla IHI. Non è stato adottato un Twin scroll , ma il condotto di scarico che alimenta la turbina è stato sdoppiato per ridurre le interferenze tra le pulsazioni delle colonne dei gas esausti dei vari cilindri . Un nuovo attuatore wastegate elettrico consente un controllo più preciso della pressione di sovralimentazione. Sul lato scarico sono ora presenti sia L'audi valve lift che il variatore di scarico. Potenze superiori, fino a 180kW, saranno previste in futuro, così afferma Heiduk . ( Da congress , ATZ e SAE )- 64 risposte
- 1.8 tfsi
- audi tecnologia
(e 1 altro in più)
Audi Q5 Hybrid Fuel Cell Concept (Foto Ufficiali)
nella discussione ha aggiunto J-Gian in Presentazioni Nuovi Modelli
Esordio al Bibendum per la Audi Q5 Hybrid Fuel Cell HFC - Mobilità Sostenibile - Motori - ANSA.it Fonte: Audi Q5 Hybrid Fuel Cell technical study revealed at Michelin Challenge Bibendum - Photos- 6 risposte
- audi concept
- audi idrogeno
- (e 4 altri in più)
Scelte tecniche "invisibili" ma che fanno la differenza
nella discussione ha aggiunto effecube in Innovazione Meccanica
Già l'A4 (ben inferiore a 60.000€) ha un pianale diverso da Passat, che deriva dalla Golf..- 52 risposte
- audi tecnologia
- differenze sotto pelle
(e 1 altro in più)
Audi Travolution Intelligent Traffic
nella discussione ha aggiunto superkappa125 in Elettrificazione e Tecnologie per l'Ambiente
A me sembra abbastanza inutile, troppe variabili in gioco. Però complimenti per essercisi sbattuti tanto. -
Tecnica: controllo qualità Audi A4 Ogni mese Automobilismo effettua, con l'aiuto di un esperto ingegnere del settore, il Controllo Qualità di una vettura in prova. La berlina di Ingolstadt, nel caso specifico, non presenta lacune gravi sia in fatto di assemblaggi sia per quanto concerne la scelta dei materiali. Ci saremmo aspettati solo una maggior cura costruttiva per quanto concerne la carrozzeria con una verniciatura poco omogenea, con alcune antiestetiche zone a buccia d’arancia, e luci troppo ampie tra alcuni lamierati, vedi parafango anteriore e cofano o tra le due portiere. Nelle prossime pagine troverete comunque il verdetto sulle singole sezioni della vettura e uno schema riassuntivo di come andrebbero controllate le vetture una volta uscite dalla fabbrica. Sotto ciascuna foto della Gallery allegata trovate il commento al dettaglio analizzato. E' forse il vero unico punto debole della berlina tedesca Ci saremmo aspettati infatti una maggior cura costruttiva per quanto concerne la carrozzeria con una verniciatura poco omogenea, con alcune antiestetiche zone a buccia d’arancia, e luci troppo ampie tra alcuni lamierati, vedi parafango anteriore e cofano o tra le due portiere. Nelle foto della gallery potete osservare alcuni dettagli come: - Luce ampia e incostante tra il parafango anteriore sinistro e il cofano motore. - Lodevole il locari in tessuto riciclato, alcune viti di fissaggio sono però a vista. - Riscontro poco preciso tra calandra e il cofano. - Luce ampia tra la portiera anteriore e quella posteriore. - Assemblaggio molto curato dei due gruppi ottici posteriori. Apprezzabile la presenza di due luci d’ingombro per le portiere anteriori e segnaliamo anche le guarnizioni giro-porta ben realizzate; peccato solo per alcuni difetti di assemblaggio del pannello porta e alcune viti a vista. Come spesso rilevato sulle vetture Audi, il vano motore offre un lay out ordinato, un’ampia copertura fonoassorbente ben fissata e tutti i punti di rabbocco ben in evidenza. Unico difetto, piuttosto grave, la cinghia dell’alternatore a vista poco protetta. All’interno troviamo materiali di buona qualità con rivestimenti in pelle curati, cuciture ben realizzate e plastiche morbide al tatto. Curato il trattamento superficiale della plancia e l'allineamento e l'integrazione degli air bag. Lodevole la presenza inoltre di bocchette di aerazione anche per i passeggeri posteriori. Sorprendono solo alcune lievi cadute di stile su una vettura di questo tipo come la guide dei sedili anteriori a vista, l’imperiale non fissato e soprattutto alcuni assemblaggi perfettibili, come il riscontro plancia-montanti anteriori o i quello dei pannelli copertura del tunnel centrale. Ampio, ben rivestito e regolare il bagagliaio, che offre una soglia di carico non troppo alta, un largo battivaligia in plastica, una corretta protezione per il gancio di chiusura e un pratico sistema di bloccaggio del piano di carico. Senza dimenticare la corretta illuminazione e un rivestimento piuttosto curato, se si eccettua la parte sottostante la cappelliera.
Audi, la vera storia della quattro | MotorBox | Auto | Magazine
- 3 risposte
Ho riletto Auto tecnica di agosto e mi è capitato fra le mani un articolo in cui si parla di Audi e delle innovazioni tecniche, l'ultima delle quali la concept della piccola Audi che prevede la trazione integrale utilizzando un motore elettrico da 30kw (41cv) e 200Nm di coppia posto sull'asse posteriore, mentre davanti è previsto un 1,4 tfsi da 150cv. In versione ibrida l'auto percorre 4,9 litri per 100 km con prestazioni notevoli (0-100km/h in 7,8 e 200km/h di massima). L'auto si può muovere per 100km in puro elettrico avendo batterie al litio, queste ultime si possono ricaricare dalla presa di corrente. E' interessante sottolineare come un motore elettrico per la spinta delle ruote posteriori permette di non avere ingombranti tunnel centrali sia per la versione a quattro ruote motrici che per la versione non ibrida a trazione anteriore...
- 15 risposte
- a1 projerct
- audi
(e 3 altri in più)
