Mostra i risultati del/dei TAG ''doppia frizione ibrido'' .
Trovato 2 risultati
Volvo - Doppia Frizione Ibrido Getrag 7HDT300
nella discussione ha aggiunto RiRino in Innovazione Meccanica
Il cambio della Volvo 40.1 & 40.2 Concept 2016 ibrida, doppia frizione 7 marce con modulo elettrico dovrebbe essere questo 7HDT300 Zoom Specifications Max. torque capacity (in Nm) 300 Weight (in kg) 95 Installation length (in mm) 368 Input shaft - differential axial distance (in mm) 188-197 Gear speed ratio 8,6 Used in these cars: Otto and electro In automobile manufacture, hybrid drives usually combine a combustion engine with an electric motor. Both drives can take on different tasks such as supporting acceleration via boosting, recovering energy during braking (recuperation) or charging a battery – through to pure electric driving. The GETRAG PowerShift dual clutch transmission can be hybridised according to the torque-split principle. This means the original drivetrain does not have to be changed as the electric motor is mounted directly on the transmission. Fuel savings of up to 80 % This design is very economical and extremely flexible for car manufacturers since it makes it easy to use electric motors with various power levels. The result is a wide variety of hybrid drive types to meet different customer requirements: from mild hybrid to full hybrid through to plug-in hybrid. For example, a mild hybrid may manage with a 15 kW electric motor while a plug-in hybrid that is recharged from the socket may need a 90 kW motor. PowerShift transmissions in a torque split design allow fuel savings of up to 15 % for a mild hybrid and up to 80 % for a plug-in hybrid. http://www.getrag.com/media/media/videos_1/2015_8/20150915_GETRAG_7HDT300_001.mp4 Animation HybridDrive Learn more about hybrid transmissions at GETRAG. The video shows the current 7-speed hybridised dual clutch transmission 7HDT300 as mild hybrid with 48V as well as the plug-in version with up to 400V. http://www.getrag.com/en/products/hybriddrive/hybrid_transmissions.html Caratteristiche e specifiche tecniche http://www.getrag.com/media/products/hybriddrive/7hdt300/7HDT300~1.pdf http://www.getrag.com/media/products/hybriddrive/7hdt300/Press_information_7HDT300.pdf http://www.getrag.com/media/media/text/cti_2015/2015_12_GETRAG_Lecture-Modular-Hybrid-Transmission-Kit.pdf- 1 risposta
- 4
- magna 7hdt300
- getrag ibrido
- (e 14 altri in più)
Fiat 500 Hybrid - Tech (Foto Ufficiali)
nella discussione ha aggiunto The Summarizer in Presentazioni Nuovi Modelli
Messaggio Aggiornato al 13/04/2011 FPT/CRF - IBRIDO in casa Fiat Via Omniauto.it Da: Fiat 500: la versione ibrida nel 2014?- 43 risposte
- fiat 500 hybrid
- ibrido
