Mostra i risultati del/dei TAG ''gran turismo'' .
Trovato 18 risultati
Genesis X Gran Racer Vision Gran Turismo Concept 2024
nella discussione ha aggiunto j in Presentazioni Nuovi Modelli
- genesis
- genesis concept
- (e 5 altri in più)
Škoda Vision Gran Turismo Concept 2024
- skoda
- skoda vision
- (e 6 altri in più)
Genesis X Gran Berlinetta Vision Gran Turismo Concept 2023
- 5 risposte
- genesis
- genesis concept
(e 5 altri in più)
http://media.mclarenautomotive.com Prime immagini della granturismo McLaren. Al solito, non mi fa impazzire.
- 24 risposte
- 3
- mclaren gran turismo
- gran turismo
Evoluzione del precedente Vision Gran Turismo Coupé, vuole esserne la sua variante Endurance. Press Release: JULIAN THOMSON DESIGN DIRECTOR, JAGUAR JAGUAR VISION GRAN TURISMO SV Designed as the ultimate virtual endurance racer, the Jaguar Vision GT SV pays homage to its illustrious forebears not only in a host of styling and surfacing references but in its unique circuit board livery which nods to milestones such as the Le Mans debuts of the C-type and D-type in 1951 and 1954 respectively. ENGINEERED BY EXPERTS The streamlined, lightweight composite body structure now houses four Jaguar Racing and SV-designed electric motors to the Coupé’s three, generating a combined output of 1,903PS (1,400kW) and 3,360Nm of instant torque with the traction and dynamics benefits of intelligent all-wheel drive and torque vectoring. Acceleration from 0-60mph takes just 1.65 seconds, on the way to a maximum speed of 255mph. The task of harnessing the Gran Turismo SV’s power to deliver an even more exhilarating racing experience for gamers fell to Jaguar’s SV engineering team. JAMAL HAMEEDI ENGINEERING DIRECTOR, JAGUAR SV JAGUAR VISION GRAN TURISMO SV The Vision GT Coupé’s elegant silhouette is still clearly recognisable in the GT SV, including the curvature of the C-type and D-type-inspired fenders, and – even with the additional motor driving the front axle – the wheelbase remains unchanged at 2,721mm. Measuring 5,540mm from nose to tail, the GT SV is 861mm longer overall – a change driven entirely by aerodynamics. To deliver the increased downforce needed for greater traction for faster cornering and increased high speed stability on long straights, the GT SV has a new front splitter and a new deployable rear wing. To solve the often conflicting requirements of increasing downforce while also minimising drag, the SV team worked with Jaguar’s designers to develop a full suite of features which work together to improve dynamics, stability, performance and efficiency. In addition to the larger, more effective splitter – which produces downforce over the front axle –apertures in the front valance channel air across the face of the front wheels to reduce turbulence and help air to flow cleanly towards the rear of the car. Air passing through the wheel wells is also smoothed towards the rear via exit vents in the fenders. The completely enclosed, sculpted underbody – which includes a keel element behind the front axle to aid high-speed stability – accelerates airflow, reducing its pressure and therefore helping to reduce lift, before it exits at the rear via a large venturi. JAGUAR VISION GRAN TURISMO SV The single most effective aero feature developed for the GT SV is its deployable rear wing, inspired by endurance racing cars from Jaguar’s rich lineage, including the XJR-14. Meticulously developed from concept to final design through many iterations, the wing’s main, fixed, section wraps over and around the back of the car, blending smoothly into the rear haunches. The wing is designed as an integral element of the sculpted bodywork while also providing the aerodynamic performance required for endurance racing: two moveable sections automatically rise at speed to deliver extra downforce when needed but drop back to their nominal positions to minimise drag. As a result, the GT SV has a drag coefficient of Cd 0.398 – remarkably low for a race car – but also generates 483kg of downforce at 200mph. MICHEAL O’REGAN AERODYNAMICS SENIOR ENGINEER, JAGUAR SV ELECTRIFYING PERFORMANCE Jaguar Racing engineers developed the GT SV’s extraordinary quad-motor all-electric propulsion system. They also designed the system for the first Jaguar Vision GT car, applying all of their knowledge and experience from developing the Jaguar I-TYPE over six successive seasons. The work was split into two main projects: A second 407PS (300kW) motor to the front axle to deliver the higher power and torque ratings required. Then the thermal management system was further improved to cope with the higher loads and to ensure that sustained high speeds and extreme acceleration could be maintained throughout an endurance race. With one motor driving each wheel, the GT SV’s propulsion system generates a combined output of 1,903PS (1,400kW) and 3,360Nm torque. Each motor has its own single-speed transmission: these are designed to give the strength and robustness needed for the high torque ratings, together with minimal mass and friction for optimum efficiency, and the capability to deliver the car’s 255mph top speed. As well as electric all-wheel drive the one motor per wheel configuration also enables infinite control of lateral and longitudinal torque distribution, delivering a step-change in torque vectoring capability for even greater traction, agility, and control. Power comes from a state-of-the-art lithium-ion battery pack which is housed low down in the GT SV’s light, stiff body structure, delivering a low centre of gravity, a low roll centre and near-perfect weight distribution. JAGUAR VISION GRAN TURISMO SV JAGUAR VISION GRAN TURISMO SV INTERIOR IMAGE FOR NEWS RELEASE - CHRIS REQUEST INTRODUCING THE JAGUAR VISION GRAN TURISMO SV: THE ULTIMATE ALL-ELECTRIC GAMING ENDURANCE RACE JAMES BARCLAY TEAM DIRECTOR, JAGUAR RACING The thermal management system is enhanced by an additional liquid nitrogen circuit which provides extra capacity to enable the battery to provide maximum power for longer while remaining within its ideal temperature range. The nitrogen cooling is also linked to the boost button within the cabin to ensure that even during the most demanding operating conditions the battery will not exceed its upper temperature limit. THE ULTIMATE VIRTUAL DRIVING EXPERIENCE The unique, powertrain soundscape so fundamental to the visceral driving experience of the Jaguar Vision GT Coupé has been further enhanced for the GT SV version. Reflecting the increase in power and torque from the four electric motors to its precursor’s three, the GT SV generates a sound that is even more purposeful and distinctive, and is authentically yet futuristically Jaguar. Building to a crescendo at the 40,000rpm redline, it reflects the GT SV’s true racing DNA and delivers unrivalled driver reward. The experience is heightened by an interior designed for racing. The pure, sweeping surfaces within the cockpit truly envelop the driver and position the instruments and perfectly weighted controls exactly where they need to be. Every component is beautifully crafted with absolute precision from advanced lightweight materials, including the new TYPEFIBRE fabrics used to cover the two sculpted composite seats. TYPEFIBRE is an innovative system of performance materials being developed by Jaguar to deliver a lighter alternative to leather with outstanding comfort and durability. TYPEFIBRE fabrics will be tested by Jaguar Racing in the I-TYPE 5 during season 7 of the ABB FIA Formula E World Championship.
- 9 risposte
Audi e-tron Vision Gran Turismo Concept 2018
nella discussione ha aggiunto MotorPassion in Presentazioni Nuovi Modelli
Ragazzi non so se questa sia la sezione corretta, eventualmente vedete se spostarla, volevo aprirla nella sezione Sport Motoristici ma anche li mi pareva fuori posto. Fonte: www.netcarshow.com Posso dire ... secondo me figherrima.- 10 risposte
- auto in arrivo
- novità auto
- (e 10 altri in più)
Bugatti Vision Gran Turismo Concept 2015
Messaggio Aggiornato al 14/09/2015 carscoops Press Release: Bugatti- 44 risposte
- bugatti
- bugatti concept
(e 3 altri in più)
Hyundai N 2025 Vision Gran Turismo Concept 2015
Messaggio Aggiornato al 15/09/2015 carscoops Press Release: Hyundai Hyundai presenterà a Francoforte la sua divisione sportiva N mediante questo concept Vision Gran Turismo Inoltre vedremo la nuova i20 WRC e la RM15 Concept già vista a Seoul.- 11 risposte
- gran turismo
- gran turismo 2015
(e 2 altri in più)
SRT Tomahawk Vision Gran Turismo Concept 2015
nella discussione ha aggiunto AleMcGir in Presentazioni Nuovi Modelli
carscoops.com Press Release: FCA- 20 risposte
- gran turismo
- srt
- (e 3 altri in più)
Peugeot Vision Gran Turismo Concept 2015
Messaggio Aggiornato al 06/05/2015 Teaser per lo studio di una supercar firmato Peugeot.- 19 risposte
- concept
- gran turismo
Volkswagen GTI Supersport Vision Gran Turismo Concept 2015
WCF Secondo concept Volkswagen per Gran Turismo- 11 risposte
- gran turismo
- gran turismo 2015
(e 2 altri in più)
Renault Alpine Vision Gran Turismo Concept 2015
nella discussione ha aggiunto Regazzoni in Presentazioni Nuovi Modelli
carscoops Press Release: Alpine- 7 risposte
- alpine
- alpine concept
Chevrolet Chaparral 2X Vision Gran Turismo Concept 2015
carscoops Press Release: Chevrolet Non so cosa aspettarmi, dato che dalla foto potrebbe anche essere una planetaria con il marchio Chevrolet appiccicato su . Opterei, comunque, per una barchetta.- 7 risposte
- chevrolet
- chevrolet concept
- (e 4 altri in più)
Subaru VIZIV GT Vision Gran Turismo Concept 2015
carscoops Press Release: Polyphony Digital & Subaru Anche Subaru prende parte alla campagna Vision Gran Turismo con una nuova VIZIV. Presentata ufficialmente- 4 risposte
- concept
- gran turismo
(e 3 altri in più)
Aston Martin DP-100 Vision Gran Turismo (Foto Ufficiali)
Press Release : Aston Martin Anche Aston partecipa al gioco con un suo concept che verrà presentato in toto domani.- 15 risposte
- aston martin
- dp-100 vision gran turismo
(e 2 altri in più)
Nissan Concept 2020 Vision Gran Turismo (Foto Ufficiali)
Messaggio Aggiornato al 16/06/2014 WCF Press Release : Nissan Dopo BMW, Volkswagen e Mitsubishi tocca anche a Nissan, che ci anticipa il suo concept per Gran Turismo 6, con una carrellata di tutti i 148 modelli impiegati nel gioco dalla prima serie della fortunatissima saga.- 7 risposte
- gran turismo
- nissan concept
(e 1 altro in più)
BMW Vision Gran Turismo Concept (Foto Ufficiali)
M-Power Concept per Gran Turismo 6, immagino semplicemente virtuale, con base M235i Racing che ricorda i fasti della 3.0 CSL.- 4 risposte
- bmw
- bmw concept
(e 3 altri in più)
Maserati Gran Turismo S Automatic (Foto Ufficiali)
da AutoWeek.nl anche questa a Ginevra
