Mostra i risultati del/dei TAG ''renault clio'' .
Trovato 21 risultati
- 44 risposte
- 5
- 93 risposte
- renault clio
- renault
- (e 5 altri in più)
Renault unveals the All-new Clio, the fifth opus of its icon, already sold at 15 million units. Since it was first released in 1990, Clio has become the Renault Group’s worldwide best-seller. The vehicle, the most often honoured by the French as their favourite car, has even risen to become the leading model of the B segment in Europe. Between 2012 and 2018, sales of it increased year on year (reaching a total of more than 450,00 units sold in 2018 over the world), an exceptional commercial performance! The All-new Renault Clio sparks an interior revolution It takes just an instant to notice. Perceived quality and driving station ergonomics were set as priorities for the All-new Clio interior design teams. The cabin takes on a new dimension in perceived quality with high-end materials, a soft coating on the dashboard, door panels and central console surround, and meticulously finished furnishings. Featuring a more compact design to free up space and integrating more in-car technologies, the All-new Clio's all-new “Smart Cockpit” is driver-focused. The wave-like shape underlines the impression of width. Equipped with the widest screens in the segment, it provides resolutely modern ergonomics for a more immersive driving experience. The All-new Clio also makes innovations unique to the segment broadly accessible, among them an electric parking brake, which is particularly useful in city driving. A more modern and expressive exterior design More elegant and dynamic from all angles, the All-new Clio inherits the sensual shapes of the previous generation. The new model gains in expressiveness while keeping its sleek profile. At the front, the hood incorporates ribs for a sculpted effect. The grille is bigger and the front bumper is more pronounced with a very expressive central air scoop that promotes good engine cooling. In terms of size, the All-new Clio is 14 mm shorter (length 4048mm, width 1798mm) but more spacious inside. The body has been lowered by up to 30 mm (height 1440mm) for better aerodynamics and extra athleticism. The 17-inch wheels (depending on the version) enhance the new model’s dynamic look. Details such as the shark fin antenna, the 100% LED lights, the flush tailgate and the chrome-plated side-window surrounds serve to modernize the exterior and improve perceived quality. The All-new Renault Clio, always sleeker, always more elegant The All-new Clio also comes in a wide choice of finishes offering a unique style: The All-new Clio R.S. Line, with more psorty lines will gradually replace the old GT Line The All-new Clio Initiale Paris, has a unique and elegant design, which will soon be available on the new models of the Renault brand. via Renault Renault Clio press pack ———————————————————————————————— SPY TOPIC ⤵️ https://www.autopareri.com/forums/topic/64823-renault-clio-v-prj-bja-spy IBRIDO RENAULT ⤵️ https://www.autopareri.com/forums/topic/67196-renault-e-tech-hybrid-ibrido-a-4-marce-senza-frizioni ————————————————————————————————
- 369 risposte
- 5
- renault clio 2019
- renault clio
(e 3 altri in più)
Freno motore Clio V E-Tech Full Hybrid in discesa a batteria carica
nella discussione ha aggiunto rossocupo in Elettrificazione e Tecnologie per l'Ambiente
Premetto che io l'ho guidata per un breve test in città pianeggiante, e salvo ritardi dovrei entrarne in possesso entro metà Novembre, vorrei sapere se hai percorso discese lunghe e mediamente ripide, e come ti sei trovato. Leggendo vari forum ,pare che una volta che si raggiunge carica batteria 100% l'auto vada in elettrico e scompaia del tutto il freno motore e bisogna affidarsi solo ai freni,i quali se discesa di qualche chilometro tendono a surriscaldarsi e a rendere pedale del freno spugnoso e in casi limiti si è pure costretti a fermarsi per lasciarli raffreddare.Visto che lamentele sono tante e non solo su Forum italiani,vorrei sapere se tu o altri hanno questo problema, che mi pare più una questione di logica centralina ,che come tu hai accennato non mi pare gestica al meglio cambiate in generale e logica quando motore termico deve rimanere acceso e a volte vada un pò nel pallone- 37 risposte
- freno motore
- renault
- (e 7 altri in più)
Renault Clio V E-Tech Full Hybrid in prova
Vettura provata con 150 km all'attivo, praticamente nuova Km totali del test 600 la mia pagella ESTERNO - 8 nel complesso classica la sua linea, nulla di nuovo, non hanno stravolto la linea della serie IV che ha venduto tantissimo, potevano osare di più nella coda. Bello il frontale. POSTO GUIDA -8 Completamente nuova rispetto alla serie precedente, comoda e tutto a portata di mano, sedili molto belli in questo allestimento di lancio. Spazio nella norma FINITURA – 8..0 Anni luce avanti rispetto alla serie 4, da vedere da toccare da usare. Bel lavoro, per una segmento B nulla da dire, ABITABILITA’ – 7.5 Viste le dimensioni nulla di miracoloso, ma comoda anche i 4, bagagliaio perde spazio per la presenza delle batterie e di parte del sistema Ibrido, comunque sempre buono sui 300 litri utili. DOTAZIONE DI SERIE – 8.0 Già di serie anche su allestimenti più bassi ha molto e di utile, dai full led ai sistemi di assistenza alla guida, ampia la scelta di dotazioni in opzione,. ci si può sbizzarrire per bene. INFOTAINMENT – 8 Clio nel 2012 ha lanciato, se non erro la moda dei tablet in plancia, ora ha rinnovato tutto, diverse possibilità di scelta per dimensioni e dotazioni, ben studiato e Sw di gestione, che permette la gestione intuitiva di quasi tutto, peccato che permane qualche rallentamento ogni tanto, e qualche problema di connessione con alcuni smartphone, tutto sicuramente migliorabile con aggiornamenti. Ma nel complesso impianto molto bello da vedere, da usare e ricco di funzioni, MOTORE – 7.5 La scelta del motore 1.6 aspirato unito alle unita elettriche, aveva come obbiettivo quello del contenimento dei consumi, e posso dire senza problemi che i 21 al litro di media nell'uso di tutti i giorni normale si fanno senza problemi, quindi missione compiuta, ovvio non fatevi distrarre dalla potenza totale, non guiderete una vettura sportiva. CAMBIO 7, la parte che più mi ha lasciato perplesso, se si guida rilassati senza chiedere troppo dai motori si comporta bene, se si alza il ritmo, le cambiate non sono sempre azzeccate, secondo me va rivista e migliorata la sua logia di funzionamento. COMPORTAMENTO DINAMICO – 8.0 Passa avanti non da poco con il nuovo telaio, la vettura nonostante il peso superiore alle sorelle con motori termici normali, risulta molto agile e piacevole da guidare, sia nella guida in città che su percorsi ricchi di curve, assetto meno alla francese della 4 serie, nel complesso è piaciuta molto CONSUMO 9 Difficile farla consumare tanto, se guidata con un poco di attenzione regala percorrenze superiori ai 22 al litro, di norma senza problemi si rimane sui 20 litro reali, anche qualcosa di più, e calcolando il peso e le prestazioni , non sono assolutamente male ed in linea con la principale concorrente, la Yaris. Impianto Frenante 8 Frena bene, con spazi d'arresto molto contenuti, e senza scompensi anche in caso di frenate brusche. CONFORT – 8 Comoda ben insonorizzata, se si guida da ibrida sena forzare i ritmi, i cambi marcia risultano azzeccati e dolci, ed il rumore a bordo rimane molto filtrato. Principali pregi Buoni i consumi ed il piacere di guida, ed interni completamente rifatti , piacevoli al tatto ed alla vista. Difetti. qualche errore dall'impianto multimediale, cambio non sempre pronto nelle cambiate. IN CONCLUSIONE: Ho avuto diverse Clio nella mia vita, la serie attuale mi pare riuscita e molto matura. Non male come sempre il rapporto prezzo reale/dotazioni. La prima versione Full Hybrid mi pare riuscita, gestione del cambio automatico a parte, da aggiornare. Video prova completa -
Ho notato che ultimamente nel nostro forum ci sono diversi possessori di New Clio III. Per questo motivo ho deciso di creare questa sezione,per parlare della nostra Clio III,come ci troviamo,i nostri problemi,i consigli. Insomma,di tutto..... requisiti? avere esperienze con una Clio III.
- 896 risposte
Dilemma auto nuova: Benzina o Ibrida?
una domanda ha aggiunto robinhood in Consigli per l'Acquisto dell'Auto
Ciao a tutti! Ero convinto al 99% di prendere la nuova 208 (1.2 / 100CV) benzina. Mi piace molto la linea e con l'allestimento Active me la offrirebbero sui 14900€. Poi girando per i concessionari, mi hanno fatto provare la nuova Clio ibrida (1.6 / 140CV) allestimento Zen, e mi sono istantaneamente innamorato del cambio automatico oltre ad essermi venuta voglia di approfondire la questione dell'ibrido. Il costo ovviamente sarebbe decisamente superiore, parliamo di 18500€, 3500€ circa in più della 208. (Son anche andato dalla regina delle ibride, Toyota, e la nuova Yaris mi costerebbe uguale alla Clio, solo che come design e interni preferirei quest'ultima) Considerato che faccio circa 18-20mila km/anno, 9km al giorno di tangenziale per lavoro, il resto città e ogni tanto qualche gita fuori porta nel weekend (una 20 di km per la montagna/mare soprattuto in estate), cosa mi potrebbe convenire? I miei dubbi sono i seguenti: - Questi 3500€ in più, li recupererò poi in breve termine risparmiando con l'ibrido? - La manutenzione dell'ibrido sarà più ostica? Fra 10 anni le batterie saranno ancora "valide" o dovrò pagare profumatamente per sostituirle e l'ibrido poi mi consumerà di più? (mi piacerebbe tenermi la macchina il più possibile e non doverla cambiare fra 3/4 anni) - Mi conviene "rischiare" o rimanere sul tradizionale al "sicuro" con una segmento B a benzina? Grazie.- 24 risposte
- acquisto auto
- auto ibrida
(e 2 altri in più)
Press release: RENAULT Ecco la rinnovata Clio, modificata nel frontale e nella fanaleria. Decisamente meglio, imho.
- 69 risposte
- renault clio 2012
- clio
- (e 8 altri in più)
Messaggio Aggiornato al 14/11/2015 WCF Press Release: Renault Prezzo: -------
- 14 risposte
- clio r.s. trophy 2015
- ginevra
- (e 6 altri in più)
PRESS RELEASE Concept per la Clio RS più potente.
- 66 risposte
- sondaggio
- auto in arrivo
- (e 16 altri in più)
Messaggio Aggiornato al 13/06/2016 Nuovo modello ristilizzato: Renault Clio Facelift 2016 .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"].jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"].jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"].jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"].jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"].jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"].jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"] .jpg"].jpg"] .jpg"] .jpg"] Renault - Carscoop Press Release : Renault Prezzi: Eccovela qua. Ricordo ancora la mia delusione quando uscì Clio III a causa del suo posteriore cicciottoso; adesso non posso che essere felice e soddisfatto del risultato ottenuto dalla Régie con il suo modello di punta. Originale, sportiva, particolare come dovrebbe essere una Renault : c'è tutto! Aspettiamo le altre foto ! Unico neo, forse, i leds integrati nella calandra anziché nei proiettori.
Renault Clio IniTiale Paris [Nuovo Allestimento]
Messaggio Aggiornato al 05/10/2014 carscoops carscoops WCF dal configuratore francese la IniTiale!- 12 risposte
- clio initiale paris 2014
- initiale paris
Renault Clio Costume National [Nuovo Allestimento]
nella discussione ha aggiunto Pandino in Presentazioni Nuovi Modelli
Autoblog Carina- 5 risposte
- clio costume national 2014
- renault
- (e 3 altri in più)
[Brazil] Renault Clio 2013 (Foto Ufficiali)
Noticiasautomotivas.com.br Renault Clio 2013 com visual reestilizado é divulgado Stupenda Le bande bianche però fanno cacare...- 17 risposte
- brasile
- clio (brasile) 2013
Renault Clio Collection (Foto Ufficiali)
WCF Press Release : Renault (L'immagine non raffigura la Clio Collection) Quindi la storia si ripete, dopo la Clio Storia ecco arrivare la Collection, che sarà svelata a breve a quanto pare! Come riportato nell'articolo, non sono escluse modifiche esterne... ma dato il periodo non ci giurerei.- 38 risposte
- clio collection 2012
- parigi
Renault Clio IV - Prj. X98 - (Spy da Pag. 6 e 18)
nella discussione ha aggiunto The Summarizer in Scoops and Rumors
Messaggio aggiornato il 12/06/2012 -
Renault Clio RS Facelift (Topic Ufficiale - 2009)
nella discussione ha aggiunto Touareg 2.5 in Renault e Alpine
Messaggi Aggiornati al 08/01/2012 km77 Prezzi : --------- 46 risposte
Renault Clio Sportour Facelift (Topic Ufficiale - 2009)
Messaggio Aggiornato al 30/05/2012 km77 da Renault.comPrezzi : --------- Ecco, l'anteriore mi fa pensare ai soldati bianchi di guerre stellari.. quelli col casco..- 13 risposte
- clio 2009
- clio estate
Renault Mégane e Clio XV de France [Nuovo Allestimento]
nella discussione ha aggiunto Ospite in Presentazioni Nuovi Modelli
Allestimento "heritage" disponibile su tutta la gamma Mégane e per la Clio top di gamma. autorevue.cz- 4 risposte
- ginevra
- ginevra 2011
Renault Clio 20th [Nuovo Allestimento]
omniauto.it Versione celebrativa per i 20 anni della Clio.- 8 risposte
- renault
- renault clio
(e 2 altri in più)
Renault Clio Phase II (Spy da Pag. 7)
nella discussione ha aggiunto Touareg 2.5 in Scoops and Rumors
autoplus Oh, che orrore- 150 risposte
