Mostra i risultati del/dei TAG ''vag tecnologia'' .
Trovato 39 risultati
VAG - Nuovo 3 cilindri 1.0 TSI - 200 kW
nella discussione ha aggiunto dindi in Innovazione Meccanica
Tratto da WCF : " Following the new twin-turbo 6.0-liter W12 TSI engine, Volkswagen has also revealed a new 1.0-liter TSI unit at the Vienna Motor Symposium. It is based on the 1.0-liter motor that is mounted in the current VW Polo and has a maximum power of 272 PS (200 kW) and 270 Nm (199 lb-ft) of torque. Using the “genes of the Polo WRC's rally engine”, the powerplant features a monoscroll turbocharger and an e-booster system. Dr. Heinz-Jakob Neußer, member of the board of management for the Volkswagen brand with responsibility for development and Volkswagen Group head of powertrain development, commented that the high-performance engine is “a nice example of just how much potential combustion engines still have in them "- 24 risposte
- vag tecnologia
- tsi
- (e 5 altri in più)
The MQ281 has a torque spectrum of 200 to 340 N·m, which means it completely or partially supersedes the current Volkswagen gearbox designs with the internal designations MQ250 and MQ350 respectively. The MQ281 is based on a 2.5 shaft concept and boasts a high gear spread of maximum 7.89. On the one hand, this guarantees good driving off performance—even for heavy vehicles with large wheels—and facilitates, on the other hand, downspeeding, which is (fuel-saving) driving in high gears with low engine speed. Development of the new gearbox focused primarily on improving efficiency. Here we employed virtual development methods. This enabled us to design a completely new oil conduction system. Using a variety of oil conduction measures, we are able to achieve a uniform and optimum lubrication of gear wheels and bearings, reducing the amount of lifetime oil required to just 1.5 liters. —Helmut Göbbels To further reduce friction, a bearing concept adapted to the gearbox was developed. The design used friction-minimized bearings with low-contact seals. Material use and its distribution for the gearbox housing was also optimized. With the aid of a further virtual development tool, a strength-optimized housing structure could be designed. The new housing supports the noise requirements of today (avoidance of undesired secondary noises) and therefore ensures improved driving comfort through less audible and noticeable vibrations in the vehicle. As is the case with many Volkswagen gearboxes, the MQ281 is produced in-house. SEAT Componentes, together with Martorell and Barcelona, one of the three production centers for the Spanish brand and simultaneously part of the production portfolio for Group Components, has started production of the new MQ281 gearbox. Up to 450,000 units can be built per year. Re-sorting gearbox production goes hand-in-hand with the production start of the new MQ281. While the new six-speed gearbox is being produced in El Prat de Llobregat and Córdoba (Argentina), the MQ200 manual gearbox has been primarily relocated to ŠKODA Components in Mlada Boleslav (Czech Republic). At the same time, the component plant in Kassel is concentrating on the production of the dual clutch gearbox DSG, and above all on the production of the electric drive for future vehicles built on the MEB platform. SEAT Componentes is a key plant for our company and, with the assignment of this project, for the Volkswagen Group as well. With these new gearboxes, we can increase maximum production to up to 3,500 units per day and use the facility as a reference center for efficiency, productivity and quality. —Dr Christian Vollmer, SEAT Vice President of Production and Logistics
- 4 risposte
- 2
- volkswagen mq281
- volkswagen
- (e 8 altri in più)
Volkswagen Polo e Golf TGI nuove versioni
nella discussione ha aggiunto MotorPassion in Elettrificazione e Tecnologie per l'Ambiente
Fonte: Volkswagen Newsroom- 27 risposte
- volkswagen
- volkswagen polo tgi
Faccio una scheda riassuntiva in merito al nuovo Bi-Turbo diesel che debutterà sulla nuova Volkswagen Passat 2015. Articolo completo: Tecnica, il nuovo 2.0 TDI 240 CV e 500 Nm della Passat - AutomobilismoSu Passat 2015 viene abbinato al cambio doppia frizione DSG a 7 rapporti (DQ500) e trazione integrale. Il consumo dichiarato è di 5 l/100 km ed accelera da 0-80 km/h in 4,2 sec e da 0-100 km/h in 6.1 sec, con una punta massima di 240 km/h.
- 38 risposte
- 2.0 bitdi 240 cv
- ea288 (mdb diesel engines)
- (e 4 altri in più)
VAG EA288 EVO: il nuovo 2.0 TDI del gruppo Volkswagen
nella discussione ha aggiunto Beckervdo in Innovazione Meccanica
Volkswagen presenta al Wien Symposium il suo nuovo EA288 EVO da 2.0 litri. Il nuovo propulsore sostituisce il 1.4 TDI, il 1.6 TDI ed il precedente 2.0 litri TDI. Con potenze che vanno da 100 kW (136 CV) fino a 150 kW (204 CV), mentre la coppia è aumentata del 9% (in media) su tutte le potenze disponibili. L'unità da 204 CV eroga 400 Nm di coppia costanti tra 1750 e 3000 rpm. A dare manforte all'unità termica ci pensa un sistema elettrico a 48V con una piccola batteria agli ioni di litio. Rivista completamente la linea di scarico, con il DPF posizionato più vicino allo scarico del turbocompressore (anch'esso revisionato) ed una nuova gestione della valvola EGR per garantire il rispetto delle normative Euro6D-Temp con i cicli WLTP e RDE. I primi modelli che lo utilizzeranno saranno a marchio Audi (longitudinali), mentre per l'installazione trasversale debutterà prima su Volkswagen, poi Seat ed infine Skoda. Via Autoforum.cz- 35 risposte
- meccanica auto
- innovazioni auto
- (e 13 altri in più)
VAG: abbandono del motore diesel sotto i 2.0 di cilindrata?
nella discussione ha aggiunto gpat in Notizie e Scelte Strategiche dal mondo dell'Auto
Il 1.5 TDI a oggi.. non esiste- 60 risposte
- 3
- meccanica auto
- innovazioni auto
Audi - Duos: propulsore a cilindri di sezione differente
Prendete quello che scrivo con le pinze, dato che l'ho trovato solo in un sito olandese. Audi avrebbe brevettato questa nuova architettura modulare che chiama DUOS. Praticamente - raffigurato - un quattro cilindri che presenta due coppie di cilindri dall'alesaggio differente. Presumibile per alti e bassi carichi. Per passare da un funzionamento all'altro si utilizza un secondo albero motore che tramite una camma attiva e disattiva il moto di metà motore. Via Autoblog.nl- 8 risposte
- 2
- meccanica auto
- innovazioni auto
(e 4 altri in più)
VAG Group: Nuovo 1.5 TGI Metano 130 CV
nella discussione ha aggiunto AngeloUPugliis in Innovazione Meccanica
Il nuovo motore, che sostituirà l'attuale 1.4 TGI da 110cv, montato rispettivamente su Volswagen Golf/Caddy, Seat Leon, Skoda Octavia ed Audi A3, si accinge a debuttare sul mercato, nel 2018.- 47 risposte
- meccanica auto
- innovazioni auto
(e 6 altri in più)
Audi "corre ai ripari" e mette il turbo-elettrico al suo 2.9 V6 (by Porsche, NdR) che andrà ad avere così prestazioni sovrapponibili al 4.0 V8 TFSI. Il nuovo V6, evoluzione del precedente, guadagna il sistema elettrico a 48V che muove un elettrocompressore ed un ISG. Rispetto al V6 3.0 litri della S5 - ad esempio - il nuovo V6 2.9 TFSI EVO pesa appena 21 kg in più, ma ha il comparto elettrico, un altro turbocompressore ed un elettro compressore. Questo signore potrebbe esser girato sulla R8... Via Autoforum.cz
- 4 risposte
- 7
- meccanica auto
- innovazioni auto
- (e 10 altri in più)
Aggiornamento Motori TDI "Dieselgate" - Quanti di voi hanno problemi dopo il richiamo?
Raccolgo sempre più spesso lamentele di clienti scontenti delle prestazioni dei diesel aggiornati in conseguenza al caso "dieselgate". Il caso più evidente riguarda alcuni dei 1.6 TDI, dove in molti lamentano un sensibile calo della reattività ai bassi giri (vuoto in basso) e talvolta problemi al gruppo EGR, che VAG fornisce assieme allo scambiatore di calore della stessa. Quasi nessuna lamentela, almeno per ora, riguardo le prestazioni dei 2.0 TDI. Mi rivolgo quindi ai proprietari delle auto coinvolte e che hanno eseguito l'aggiornamento: avete notato differenze rispetto a prima? V'invito a rispondere al sondaggio e ad integrare il tutto con un messaggio, indicando: - quale motore avete; - anno immatricolazione; - potenza in kW; - se possibile anche il codice motore (es. del 1.6 TDI esistono: CAY, CAYB, CAYC; CLH, CLHA, CLHB; CRK, CRKA, CRKB; CXX, CXXA, CXXB; CWVA; DBK, DBKA... Giusto per rendere l'idea del casino ) Attendo partecipazione, voti pubblici e possibilità di risposta multipla (per ovvie ragioni)- 30 risposte
- auto e ambiente
- riduzione inquinamento
(e 22 altri in più)
- auto e ambiente
- riduzione consumi
- volkswagen
- vag
- vag tecnologia
- volkswagen tecnologia
- dieselgate
- vokswagen dieselgate
- 1.6 tdi
- 2.0 tdi
- 1.6 tdi dieselgate
- 2.0 tdi dieselgate
- aggionamento 1.6 tdi
- aggiornamento 2.0 tdi
- richiamo
- richiamo dieselgate
- richiamo volkswagen dieselgate
- problemi volkswagen
- problemi richiamo dieselgate
- ea 189
- ea 189 dieselgate
- volkswagen ea 189
- sondaggio
VAG - DQ500 - DSG 7 Marce, frizioni in bagno d'olio, trasversale, 600 Nm
nella discussione ha aggiunto J-Gian in Innovazione Meccanica
Volkswagen Group - DSG: the New DQ500- 21 risposte
Ciclo Miller, iniezione diretta, VGT, Cylinder Deactivation e tante altre chicche tecnologiche per il nuovo EA211 Evo VW. Efficienza migliorata del 10%. Un motore simile lo ha in produzione anche Toyota. Fonte: https://www.volkswagen-media-services.com/en/detailpage/-/detail/Volkswagen-at-the-37th-Vienna-Motor-Symposium/view/3451577/7a5bbec13158edd433c6630f5ac445da?p_p_auth=5bnr37tS E' sicuramente un bel trattato di tecnica, ma sono un po' scettico sull'affidabilità complessiva, francamente.
- 41 risposte
- 6
- meccanica auto
- innovazioni auto
(e 24 altri in più)
- meccanica auto
- innovazioni auto
- volkswagen 1.5 tsi
- 1.5 tsi
- vag
- vag tecnologia
- volkswagen 1.5 tsi 130 cv
- 1.5 tsi 130 cv
- 1.5 tsi vgt
- vgt
- geometria variabile
- turbo
- turbo geometria variabile
- turbo vgt
- turbo benzina vgt
- geometria variabile benzina
- benzina
- ea211 evo
- ea211
- vag ea211 evo
- volkswagen ea211 evo
- miller
- ciclo miller
- volkswagen miller
- miller volkswagen
Audi - Trazione integrale Quattro Ultra
Quando parliamo di Quattro associato al marchio Audi, abbiamo tutti chiaro in testa che stiamo parlando di trazione integrale. Come gli appassionati ben sanno, non tutte le "Quattro" sono uguali. Nei modelli con meccanica trasversale (A1, A3, Q3) l'integrale consiste nella classica trazione anteriore il cui moto viene indirizzato all'occorrenza anche alle ruote posteriori, tramite un sistema di frizioni servo attuate. Per quanto riguarda la gamma dotata di motori e trasmissioni a disposizione longitudinale (da A4 in su) invece, negli anni vi è stata un'evoluzione più interessante: siamo passati dal differenziale centrale autobloccante di tipo Torsen, ad un più recente sistema meccanico a lamelle, fino ad arrivare alla nuova Quattro Ultra. Con la denominazione Ultra, s'intende sostanzialmente la versione "on demand" della trazione integrale per powertrain longitudinali. Il cuore è un giunto centrale a frizioni multiple, gestite da un attuatore elettrico, capace di inviare fino al 50% della coppia disponibile alle ruote posteriori. La particolarità però sta nel retrotreno, dove troviamo un differenziale di tipo aperto contenente una frizione a denti: essa è in grado di sconnettere l'albero di trasmissione quando non necessario, minimizzando le perdite di trascinamento quando l'integrale non è necessaria, un sistema simile alla versione più avanzata della Jeep® Active Drive II. I vantaggi apportati da questo sistema, si traducono principalmente nella riduzione dei consumi quando la trazione integrale non è richiesta, quantificabile secondo Audi in 0,3 litri ogni 100 km. Il sistema inoltre pesa 4 kg in meno del precedente e permette una più efficiente interazione con l'impianto frenante, facilitando l'inserimento in curva e l'indirizzamento della potenza tra ruote interne ed esterne alla curva stessa. I tempi d'intervento sono quantificabili in poche decine di millisecondi, ma a seconda del programma di guida scelto (tramite il Drive Select) il sistema può rendere disponibile l'integrale ancor prima che la stessa si riveli necessaria per problemi di aderenza. Nelle altre situazioni, la centralina gestirà la trazione Quattro Ultra tenendo in considerazione numerosi parametri attinenti la dinamica, quali velocità delle singole ruote, accelerazione laterale, angolo volante, angolo d'imbardata, erogazione motore e persino l'eventuale presenza di un rimorchio. Autopareri J-G- 27 risposte
- haldex
- quattro ultra
- (e 9 altri in più)
Un'altra applicazione del compressore elettrico, sul V6 TDI di Audi: ai bassi regimi lavora l'elettrico, poi arriva (con comodo ) l'azione del turbocompressore classico Riporto una parte dell'articolo: Articolo completo su: Audi A6 V6 TDI electric biturbo - Come va il motore con turbo elettrico - Quattroruote
- 24 risposte
- vag tecnologia
- v6 tdi electric biturbo
- (e 7 altri in più)
Audi TT Clubsport Turbo Concept 2015
Autoweek.nl Concept Audi per Wörthersee, equipaggiato con il 2.5 TFSI portato a 600 CV e 650 Nm di coppia. 0-100 in 3,6 secondi e peso di 1396kg!- 18 risposte
- audi
- audi concept
[AUDI] Nuovo 2.0 TFSI 140 kW (190 hp)
nella discussione ha aggiunto AleMcGir in Innovazione Meccanica
https://www.audi-mediaservices.com/publish/ms/content/en/public/pressemitteilungen/2015/05/07/world_premiere_at.html- 14 risposte
- 2.0 tfsi 190 cv
- 2.0 tfsi 2015
(e 3 altri in più)
VAG - 2.0 BiTDI 272 CV con Elettrocompressore e cambio DSG 10 Rapporti (DQ551)
Power Step a 272 CV con aggiunta di un electric-turbo, sistema di valvole a geometria variabile e nuovo DSG a 10 rapporti. Volkswagen unveils 272 HP 2.0-liter diesel engine with electric turbocharger Via WCF -
Audi - Brevetto motore a compressione variabile
Fallita Saab, Audi deposita il brevetto di un sistema a compressione variabile che ricorda moltissimo il sistema SVC (Saab Variable Compression) Via Autoblog.nl- 27 risposte
- audi tecnologia
- compressione variabile
- (e 3 altri in più)
[Porsche-Audi] MSB VS MLB Evo
nella discussione ha aggiunto Touareg 2.5 in Notizie e Scelte Strategiche dal mondo dell'Auto
WCF Classica scena di famiglia : Porsche si lamenta che Audi abbia rifiutato la loro Modular Standard Platform per future A6, A7 e A8 e dal canto suo critica aspramente la MLB Evo di Audi, tacciata di avere un sistema di sospensioni non all'altezza, di non essere molto flessibile ed inadeguata ai nuovi sistemi elettronici. In Lamborghini stanno addirittura pensando ad una propria struttura in fibra di carbonio. Mamma Volkswagen corre ai ripari riprendendo sia Porsche che Audi, incitando al lavoro di gruppo . Mi sembrano le liti tra i miei figli, giuro.- 7 risposte
- audi mlb
- audi tecnologia
- (e 6 altri in più)
Premessa: ammetto umilmente di essere una capra da un punto di vista tecnico. L'argomento sono le chiacchiere da bar con gli amici a tema motoristico e ci si è divisi tra quelli che celebrano "la conclamata solidità tedesca" (generalmente equamente divisi tra possessori di a3 e golf con due leon a fare da jolly)e gli altri, alcuni ex possessori pentiti, uno dei quali ha venduto per la disperazione la propria passat 2.0 TDI 140 cv per i noti problemi che questo motore tende ad avere agli iniettori, e gli scettici generici. Siccome i miei compari non sono molto più avanti di me sotto l'aspetto della tecnica, gli argomenti a favore erano la buona guidabilità ed i consumi dell'intera gamma diesel del gruppo VW, partendo dal 1.6, proseguendo con il dismesso 1.9 e arrivando agli attuali tra cui il già citato mangiainiettori. Dalla parte dei contro i più ferrati affermano che gli attuali propulsori a gasolio del gruppo VAG sono motori di concezione ormai piuttosto datata che vengono rivisti ad intervalli regolari. Si tratterebbe comunque di rivisitazioni di motori progettati svariati anni fa e non di prodotti innovativi. A sostegno di queste teorie ci sarebbe la caduta in termini di durata ed affidabilità degli stessi prodotti. A fronte del classico utente che ha il 2.0 140 cv da 10 anni, manutenzione regolare, e problemi meno di zero, ci sono 4 persone che montano il suddetto (3 audi a3 ed una golf) ed è stata una ecatombe tra iniettori e pompe del gasolio. Entrambe le Leon montano il 1.6 e hanno avuto noie (non ricordo di preciso) alla turbina (?). Io non ho elementi per poter giudicare se non i riscontri di chi l'auto la possiede e di quanto leggo su AP. Però mi incuriosirebbe sapere la vostra, da un punto di vista tecnico, sull'attuale gamma di motori del gruppozzo tedesco. Sono davvero medi/mediocri come alcuni possessori delusi o non possessori scettici li dipingono? O, girando la domanda, se uno cerca un motore a gasolio tecnicamente valido, in grado di offrire buona affidabilità e/o buone prestazioni, deve guardare altrove? C'è anche il tornaconto personale in fondo eh, intendiamoci. Esiste la possibilità che, a breve, si renda necessario il cambio della ns. auto di famiglia. Sicuramente una seg. C. Ora, io ho una Honda ed è la migliore auto che abbia mai guidato. Sono estremamente soddisfatto della sua razionalità e del modo che la casa giapponese ha di concepire l'auto. Infatti ho cominciato a "puntare" la nuova Civic tourer che però ha già due difetti non da poco: Primo: Sicuramente non sarà a buon mercato, l'esperienza attuale insegna. Secondo: A differenza della mia Jazz, "a pelle" non mi piace non mi "chiama". Mi "chiama" e molto, l'attuale Octavia, mi piace da impazzire. Però, se i propulsori che monta e, complessivamente parlando, se c'è tanta differenza qualitativa tra il costruttore giapponese e il gruppo tedesco, rimarremo in honda, complice anche un'esperienza individuale estremamente positiva. L'idea di base, comunque, è liberarmi delle chiacchiere dei tifosi e di capire con voi come davvero stanno messi i crucchi, marketing a parte. Vi ringrazio in anticipo
- 28 risposte
- motori vag
- vag motori
(e 1 altro in più)
Volkswagen: 1.8 TFSI in USA e migliorie tecniche su tutta la gamma
Via GreenCarCongress- 1 risposta
- 1.8 tfsi
- 1.8 tfsi 2014
VAG - 1.4 TSI con Cilindri Disattivabili
nella discussione ha aggiunto crabble in Innovazione Meccanica
Articolo interessante che parla della disattivazione di due cilindri anche per i motori 4 cilindri in linea Da WardsAuto.com Small-Displacement Engines Integrating Cylinder Shutdown- 56 risposte
- 1.4 tsi cilindri disattivabili
- act
VAG - 1.2 TDI: nuovo 3 cilindri a gasolio
Via Globalmotors.net- 33 risposte
VAG (Audi) - Nuova versione 1.8 TFSI
nella discussione ha aggiunto simonepietro in Innovazione Meccanica
In uscita a breve su A4 e A5 . Il lancio del nuovo motore 1.8 TFSI l segna la terza generazione di questa fortunata famiglia di quattro cilindri usata da Audi. E 'stato completamente rivisto, al fine di raggiungere gli ambiziosi obiettivi di emissioni di CO2 e garantire la sua conformità con le future norme sulle emissioni Euro 6. La nuova generazione offre numerose tecnologie innovative, tra cui un sistema di raffreddamento dei gas di scarico integrato nella testa del cilindro, un sistema a doppia iniezione con iniezione diretta e indiretta , così come il sistema Audi valvelift su entrambi gli asse a camme. Una gestione completamente elettronica del sistema di raffreddamento . Il nuovo 1.8 TFSI ,da 125 kW di potenza e 320 Nm di coppia , emette livelli di CO2 inferiori fino al 22% rispetto alla uscente uscente versione da 118kW / 250Nm . Il raggiungimento di questi obiettivi ha imposto l'aggiunta di un carico di tecnologia, addirittura due sistemi di alimentazione ad iniezione ed un sistema integrato a livello di collettore di scarico. Il dottor Thomas Heiduk, ha dichiarato: "Al fine di ottemperare alle future norme sulle emissioni, abbiamo scelto di utilizzare due distinti circuiti di alimentazione. Così all' l'iniezione diretta abbiamo aggiunto anche l'iniezione indiretta. Quest'ultima viene utilizzata a carico parziale, offrendo una riduzione delle emissioni e una migliore efficienza . " Il sistema di iniezione diretta con pressione a 200 bar ,viene utilizzato durante l'avviamento del motore e con elevati carichi di potenza , mentre il sistema di iniezione indiretta viene utilizzato a carichi parziali dato che offre una migliore formazione della miscela in tali condizioni , inoltre riduce al minimo le emissioni di particolato. L'efficienza è migliorata anche grazie all'adozione , prima applicazione su un Audi ,di un collettore di scarico raffreddato ad acqua. Questo aiuta a ridurre il peso e riduce i tempi di entrata in temperatura del motore . " il nuovo collettore di scarico permette di fare a meno dell' arricchimento a pieno carico e in tal modo il consumo di carburante può essere ridotto significativamente," parole di Heiduk. Il circuito di raffreddamento stesso è stato ridisegnato. La gestione termica non avviene più tramite un termostato, ora la pompa dell'acqua e due valvole elettromeccaniche sono gestite elettronicamente . Il turbocompressore è fornito dalla IHI. Non è stato adottato un Twin scroll , ma il condotto di scarico che alimenta la turbina è stato sdoppiato per ridurre le interferenze tra le pulsazioni delle colonne dei gas esausti dei vari cilindri . Un nuovo attuatore wastegate elettrico consente un controllo più preciso della pressione di sovralimentazione. Sul lato scarico sono ora presenti sia L'audi valve lift che il variatore di scarico. Potenze superiori, fino a 180kW, saranno previste in futuro, così afferma Heiduk . ( Da congress , ATZ e SAE )- 64 risposte
- 1.8 tfsi
- audi tecnologia
(e 1 altro in più)
